Need BIOS rom file for Dell 7720
    Could someone please extract me the rom file from this .exe
    (https://downloads.dell.com/FOLDER030.../1/7720A17.exe) as I cannot get it to extract on my other laptop as it is not a Dell laptop?
    My Dell 7720 requires the bios to be rewritten as it is corrupt.
    I can get it to look at the usb stick to load the rom file but as Dell only supply it as an exe file I cannot extract it.
    I have tried using '7720A17.exe -WriteRomFile' and it says it is going to do it but then stops without extracting the file (needs to run as administrator but even then it won't let me extract it).
    I would be most grateful if anyone with a 7720 could extract me the rom file.
    Thanks.
    Re: Need BIOS rom file for Dell 7720
    Can anyone help before I give up on it and use it as a doorstop?
      Thanks.
      check this
      http://forums.badcaps.net/forum/showthread.php?p=555427
      you can extract from 7720a17.exe but you will found only bios.cap, not full bios... no meregion,no descriptor region...only biosregion
      check this.. extract temp.zip
        Thank you, I will let you know if I am able to revive it or not.
        Thanks again :-)
          DA0R09MB6H1- Is This your Mobo code??
          If So then i have the dump
