Packard Bell EG70 bios dunp needed
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    Please i need this bios....Thanks
  • Pascal Komlassan
    • Jan 2017
    • 809
    • TOGO
    Re: Packard Bell EG70 bios dunp needed
    Somebody can help me please. ..
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      make backup of bios and post it here i will fix serial number and uuid
      next time try to give more usefull info if you want help
      Packard Bell EG70
      EN LE11BZ
      2 bios
      Im Back... sort of...
      • Pascal Komlassan
        • Jan 2017
        • 809
        • TOGO
        thanks bro Ala borbe your bios is different.
        HannStart J
        MV-4 E89382
        94V-0
        this is the old backup of my mother board
        • Pascal Komlassan
          • Jan 2017
          • 809
          • TOGO
          Somebody can help me please. ...
          • ala_borbe
            aka Donald
            • 1625
            • Malta
            its so much easyer when you have info
            try this
            Packard Bell.Easynote LE69KB
            ive fixed you serial number and model info
            • Pascal Komlassan
              • Jan 2017
              • 809
              • TOGO
              thanks bro ala-borbe is on but all of the Usb port is not working....please have you some solution of this blem? thanks
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                chipset reflow?
                • Pascal Komlassan
                  • Jan 2017
                  • 809
                  • TOGO
                  no bro...
                  • Pascal Komlassan
                    • Jan 2017
                    • 809
                    • TOGO
                    Please bro this is the image of motherboard...
                    • jasko_jacker
                      • Oct 2014
                      • 1137
                      • italy
                      For the usb check the 5V on usb port.
                      If this tension is not present check the usb power chip, if is present probably a chipset issue. If you have the schematic post it
                      • nicolasbar
                        • Nov 2020
                        • 10
                        • españa
                        Hello, I don't know if the bios I have can help you, one is from my own laptop and the other is downloaded from wed pages.
                        I hope to do it well, I explain what happens in mine is that it does not give an image, what I do notice is that if I put a flashlight on the screen, flashes are perceived, I cannot investigate further why I am missing the diagram, if someone has it , if I can publish it.
                        • nicolasbar
                          • Nov 2020
                          • 10
                          • españa
                          https://www.badcaps.net/forum/attach...1&d=1605729360
                          • maxlove70
                            Need Bios Packard Bell iSTART 2356
                            by maxlove70
                            Hello, I'm searching Bios for Packard Bell iSTART 2356.
                            Asus for Packard Bell M2NS-NVM (Boston) 0206 BIOS - 6A69NA01
                            Manufacturer and model: Asus for Packard Bell M2NS-NVM (Boston)
                            Chipset: AMD 1100
                            Part number: 6A69NA01
                            BIOS ID: 03/05/2007-NF-MCP61-M2NS-NVM-00
                            BIOS Release date: 2007-03-05
                            BIOS Revision: 0206
                            Packard Bell Support for this PC is discontinued.
                            Please Help Me !!!!
                            Thanks.
                            02-16-2023, 11:52 AM
                          • tlindi
                            Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                            by tlindi
                            Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                            Ack
                            Ack
                            01-30-2025, 04:26 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • Verlengsnoer
                            Packard bell lv11hc bios repair
                            by Verlengsnoer
                            hi all,
                            ive got a packerd bell lv11hc with a bad bios,
                            the laptop works but reboots randomly and after reboot it freezes on windows loading,
                            i found a acer v3-771g bios here on the forum when i was searching for the packard bell version, the acer bios works fine, no random reboots, no freezes, but the keyboard layout of acer and packerd bell are different.
                            thats the reason why i want the PB backup to be fixed,
                            hope someone can help me, i added the main and ec? bios files
                            greetings...
                            12-04-2022, 06:28 AM
                          • DynaxSC
                            by DynaxSC
                            11-17-2023, 10:56 AM
