HP MINI 210-2005tu bios
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: HP MINI 210-2005tu
    your file is empty in first post
    try this bios
    Im Back... sort of...
    • String2016
      • Nov 2015
      • 2238
      • philippines
      thanks ala borbe i already tried that still the same issue could you fix this please this bios dump i already attached it again thanks in advance
      • keeney123
        Lauren
        • Sep 2014
        • 2536
        Originally posted by Romulo
        Thanks for the response before os is windows 8 the problem with this laptop before bios also corrupted so i reprogram with new one i got on the hp site si netbook worka fine then i reformat to windows 10 wrks fine also after 4months customer came back tje same problem so i reprogram bios again cannot program so i chnange the bios chip now this is the problem works fine when charger only buy after shutting down cannot turn on again i need to rest for 10 mins to use it again
        Try ala_borbe bios see if that works.
        When you rest the computer do you unplug charger from wall? Is there a way you can charge the battery and then try it in computer? Also, is the RTC working?
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          i already tried alaborbe bios still the same issue after shutsdown cannot turn again lights blinking i need clean me region for this i already upload the bios
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            another problem with this cannot read flashdrive but usb and mouse read
            • keeney123
              Lauren
              • Sep 2014
              • 2536
              So lets stick on one problem at a time. Lets deal with the power issue.
              When you boot up can you get into the bios screen?
              • Romulo
                • Nov 2016
                • 484
                • Philippines
                #27
                when shut it down i unplugged the charger but when i plugged back in again lights are blinking cannot turn it on i need to rest first for a about 10-20minutes after that when i plug in again the lights are not blinking now and i can turn on and boots fine even hours of using,RTC BATTERY is working shows 3v
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  #28
                  Anyone please help on this problem
                  • keeney123
                    Lauren
                    • Sep 2014
                    • 2536
                    Here is one more thing to try. After you shut the unit down disconnect charger and then press and hold the power button for 30 seconds. Then plug charger back in and see it is will boot up.
                    It is as if a cap is charged up and it needs to discharge in order for the unit to boot up.
                    • keeney123
                      Lauren
                      • Sep 2014
                      • 2536
                      Here are more steps you can try. One is blowing out vents for heat related problems.
                      http://support.hp.com/gb-en/document/c01732674
                      • keeney123
                        Lauren
                        • Sep 2014
                        • 2536
                        On the bios screen in UEFI there is a setting called silent mode. If this is selected the USB port will be turned off during boot.
                        • Romulo
                          • Nov 2016
                          • 484
                          • Philippines
                          #32
                          update: i reflashed again with ala borbe bios and then change the laptop battery with my spare good one and make it full charge i can boot now with battery but when charger plugged in still blinking need to rest first to work again and also there is no option on the bios for usb usb keyboard and mouse works fine but flshdrive cannot read it
                          • ala_borbe
                            aka Donald
                            • 1625
                            • Malta
                            #33
                            once again, your file is empty
                            it is 2 mb but no data in it all 0xff ff ff ff, hence useless
                            try this, this is lower version bios for that model, maybe ec and bios are not comunicating as it should
                            write this file, turn on laptop the update from windows to new version (sometimes ec get updated also)
                            • Romulo
                              • Nov 2016
                              • 484
                              • Philippines
                              #34
                              thanks alaborbe i will try again with your bios file and feedback soon thank you
                              • ridamouh159
                                • Nov 2014
                                • 365
                                • maroc
                                #35
                                salam
                                you must using another ec-chip- bios and flashing anf be sure that all your 8 pin is fixed good .
                                if not working i need a diagram schematic for your mother of laptop for i can help you
                                lader i can't found it
                                if you have it put it here
                                write the name of motherboard.
                                • keeney123
                                  Lauren
                                  • Sep 2014
                                  • 2536
                                  Also, have you tried another charger on the unit?
                                  • keeney123
                                    Lauren
                                    • Sep 2014
                                    • 2536
                                    When are you trying to read flash drive on power up or after it is in OS?
                                    • Romulo
                                      • Nov 2016
                                      • 484
                                      • Philippines
                                      #38
                                      @keeney i used original ho charger and voltage is good cannot read flash in os blinking but not reading it freezes the same also in boot up cannot continue to boot in os if flashdrive is inserted but usb mouse and keyboard works with no problem
                                      • Romulo
                                        • Nov 2016
                                        • 484
                                        • Philippines
                                        #39
                                        @ridamouh i already change the chip attached is the motherboard code
                                        • keeney123
                                          Lauren
                                          • Sep 2014
                                          • 2536
                                          Have you been able to get into the bios screen? Can you post your bios screen setting.
                                          • Habble7
                                            by Habble7
                                            Suspected Cause:
                                            Troubleshooting Attempts:
                                            05-22-2025, 07:28 AM
                                          • Citymin
                                            by Citymin
                                            S/N : 5RNK9FFT70...
                                            08-05-2025, 05:12 AM
                                          • DynaxSC
                                            by DynaxSC
                                            11-17-2023, 10:56 AM
                                          • ruzhda
                                            Clean Bios dump for HP 260 G4 mini
                                            by ruzhda
                                            I am new in forum, working whit computers since Commodore 64 (own 2 defect units) And Amiga 1200,
                                            I taring to fix HP 260 G4 mini whit bios corrupted error , after reading and writing bios whit programmer pc is not powering on .
                                            I need clean dump to write new IC chip.
                                            07-21-2024, 08:10 AM
                                          • MDSI
                                            HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                            by MDSI
                                            I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                            Details:
                                            Model : HP OMEN 17-an012nf
                                            Motherboard Part Number : DAG3BAMBAF0 REV : F
                                            Serial Number (S/N) : 5CD7280D51
                                            BIOS chip : Winbond W25Q64VSIQ
                                            Programmer : EZP2023+
                                            Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                            I already...
                                            07-28-2025, 07:11 AM
