Request ZBook 15 G3 Bios Dump
https://www.badcaps.net/donate -
Re: i want bios ZBOOK-15-G3-APW50-LA-C381P-Rev:1A
I tried the BIOS but the caps looks blinking 5 times the led turn on and offLast edited by Reda123456; 01-24-2022, 04:11 AM.Comment
Re: Need Bios HP ZBook 15 G3 apw50 la-c381p
Maybe who have Bios main+ec for HP ZBook 15 G3 apw50 la-c381p ?Comment
Every donation made will go towards server fees and maintenance costs.Comment
Re: Request ZBook 15-G3 Bios Dump
Hello guys plz help me i have locked BIOS Zbook 15 G3
pleas unlock for meAttached Filesif you find these attachements useful please consider making a small donation to the site
unlockAttached Filesif you find these attachements useful please consider making a small donation to the site
https://www.badcaps.net/donateComment
Tool unlock here : https://www.badcaps.net/forum/showth...ht=rc+unlocker↵
OK perfekt thenksTool unlock here : https://www.badcaps.net/forum/showth...ht=rc+unlockerComment
Hello guys i got HP zbook 15 g3 with i7 6700HQ with motherboard: 848219-601, i took it gift from a company and i want to simple remove the logo and the serial number so i can sell it because i got newer. Can you assist me please. I tried to unlock it with MPM but i got all the times access denied.
Any help will be much appreciatedComment
pleas unlock for me
thanksAttached Filesif you find these attachements useful please consider making a small donation to the site
Sometimes it helps to read the whole thread https://www.badcaps.net/forum/showpo...2&postcount=70
Your bios backup is almost empty,try again with different software if you`re using a ch341a
https://www.badcaps.net/forum/showthread.php?t=103526Comment
Hi, thanks for the quick reply.Sometimes it helps to read the whole thread https://www.badcaps.net/forum/showpo...2&postcount=70
what can i do if i have already erased the contents of the bios chip?Comment
read this..
posteaza biosul original..Due to a lack of donations, server free space at a critical level, and possible closure of Bios Requests all donations are welcome, click:
HP zbook 15 g3 bios dump
mobo code is:c381p ...i tried ec and main file from forum but no luck .....all three old bios chips main:UE3 and ec and UT2 r missed....i tried with new 128 and 64 chips ...now notebook can turn on without a post any help will be appricatedComment
HP ZBook 15 G3 Bios needed
Greetings,
I'm in need of a repaired/modified HP ZBook 15 G3 Bios and/or EC, I will attach the bad ones as zipped (Bios + EC).
The symptom of the laptop is flashing power button led, unplugging battery and/or CMOS battery didn't help so I might aswell try to solder & reprogram the onboard chips before declaring the motherboard as faulty.
by AhariHi all,
I...-
by zlr8rGreetings
I am hoping someone could have a check of my Hp Zbook Firefly 14 G10 , 2 x 32MB Bios files... (powers on / black screen).
Serial Number: 5CG3202C16
Product #/SKU: 739P0AV
CT Number: PRTUE00WBI30YX
Description: HP ZBook Firefly 14 inch G10
BuildID: 23WWWGAZ602#SABU#DABU
Feature Byte: 476J6S6b7B7M7Q7U7W7m7saBaEapaqauawbUbhcAfPgSguhKj4jhk8mEn7nVngpDpVpWpnpqprqMqkqz.G3
MAC address not found.- I extracted both 32mb bios files (Main + EC). But when i run the main 32mb bios through MFIT.exe , it produces this error; ie:,
Channel: BIOS Requests ONLY!
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
by Habble7The Samsung S49CG934SU monitor does not power on - no LED indicator activity and no response to power button. However, when 21V power is connected, it immediately draws 0.8A of current with no display output. The motherboard processor gets warm, and there is continuous reading activity from the W25Q128BV BIOS chip.
Suspected Cause:
Troubleshooting Attempts:
Hello engineers 😀,
I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
🔧 Device Info:
- Model: HP 15-da2007ne
- Product Number: 8XF55EA#ABV
- Serial Number: CND0338P0D
- CPU: Intel Celeron N4000
- EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
💀 Problem:😅
- Device shows “Administrator Password”...2 Photos-
- Loading...
