k451 (S451LN) bios&ec need
  • r ez a
    • Sep 2014
    • 39
    • iran
    hi guys
    i need these files
    S451LN rev 2.0
    tnx all
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: k451 (S451LN) bios&ec need
    post your back up
    • r ez a
      • Sep 2014
      • 39
      • iran
      Originally posted by bluestone
      post your back up
      unfortunately i dont save read file
      • bluestone
        • Jun 2011
        • 343
        • Ghana
        what is the size of the Ec?
        • rioreno
          • Feb 2009
          • 540
          • Indonesia
          Originally posted by r ez a
          hi guys
          i need these files
          S451LN rev 2.0
          tnx all
          try this..
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            here..
            • r ez a
              • Sep 2014
              • 39
              • iran
              Originally posted by rioreno
              here..
              tnx alot
              • snsent
                • Nov 2010
                • 103
                • Malaysia
                Try this... Tested OK..
                • SVelectronica
                  • Mar 2015
                  • 5
                  • Argentina
                  thanks
                  • DrDos
                    Kenwood KR-6030 vintage stereo ,Old Man Trying to Save a Buck
                    by DrDos
                    Hello all. I'll try to keep this short. I have no knowledge of electronics. I can use a multimeter and am familiar with caps to some extent. I bought a Kenwood KR-6030 vintage stereo. It need work and so I thought I would recap the thing since I get power to the on switch but nothing else is working. No lights, no sound and so forth. I went to Mouser to order caps and I find I am way over my head. I not only do not know the type of capacitors I need but Mouser and digikey do not accept Kenwood part numbers. I have the info such as 220uF 63v and such but no place to put it. I could buy a recap...
                    08-08-2025, 03:16 AM
                  • fixitforfree
                    Samsung TV mu6179 with Mainboard BN41-02568B wont save configuration.
                    by fixitforfree
                    I have two Boards BN41-02568B for a UE55MU6179 of which one does produce a good picture (Board A) but can not save its configuration (even a factory reset will not work) and one board which produces a distorted picture (Board B). Learning from here the IC1604 saves the configuration of such a TV.
                    Before replacing the IC1604 from Board B to Board A - would that actually solve the problem from Board A not being able to store its configuration or could there be something else wrong with writing to the flashrom? Is it even the right chip to replace or should I look out for a different...
                    07-21-2025, 09:07 AM
                  • Conste
                    Clevo W25CEW doesn't save Bios settings / shutdown issue
                    by Conste
                    Hello together,
                    I have a Clevo W25CEW (Terra 1541) with some strange symptoms:
                    1. I cannot save Bios settings by pressing "save settings" in the bios. By pressing "save & exit" it will save the settings.
                    2. I can boot normally (UEFI installation), but when I shut the machine down and start it after a few seconds again it will show resume from hibernation and shutdown after POST, just before windows would boot. Then it will go back to factory settings and my UEFI installation will not boot!
                    Already changed the CMOS battery...
                    09-01-2021, 10:34 AM
                  • zmeutul
                    hi guys i need bios for 6-77-NP50PNJY-D02B-3C
                    by zmeutul
                    hey guys I need a bios for 6-77-NP50PNJY-D02B-3C.With the current one, the laptop does not start. I am also attaching the original bios. Thank you!...
                    09-26-2024, 01:55 PM
                  • KYBOSH
                    Trying to Save - Samsung UN55JS6500 - A line down the screen + Falling LED diffusers
                    by KYBOSH
                    Picked this one up today.
                    In addition to falling LED diffusers there is a single line here that maybe a deal breaker.
                    From my reading on these boards it is said that the issue is likely a sign of failed tab drivers, ribbons or tab bonding to the panel.
                    Wanted to get a 2nd opinion from you guys before I gave up the ghost.
                    Great looking TV otherwise.
                    Is there any tricks I can do to try to save this one?
                    If so, i'll gladly order a set of backlights and save this one from the landfill..
                    Thanks in advance
                    10-04-2024, 11:00 PM
