NEED Bios Hp Probook 440 GO VGA ATI
  • pepyluck
    • Feb 2015
    • 36
    • indonesia
    hei.. sorry if my english bad. my laptop died. I've checked it turns out the damage in the BIOS. I've download it that the new bios file. it turns out the BIOS series Probook 450 hp. is there any information that could change the name of my laptop because the laptop into probook 440. The office inventory
  • imranromi
    • Jan 2015
    • 1291
    • Pakistan
    Re: NEED Bios Hp Probook 440 GO VGA ATI
    try this i don't no this bios graphic and non graphic try and reply.
    • pepyluck
      • Feb 2015
      • 36
      • indonesia
      thanks for you repson. but this file cannot compatible with my laptop . because my laptop can't restart.
      • rioreno
        • Feb 2009
        • 540
        • Indonesia
        To change HP product name, use wndmifit tools bro...
        • Bloodhoundje
          HP Pavilion Gaming Laptop 15-ec2523nd - Dimm2 slot disabled after corrupt bios repair? Advice requested.
          by Bloodhoundje
          I have been doing hardware repair as a hobby for some years now and recently decided to learn about repairing laptops as a fun challenge.
          I managed to get my hands on a "HP Pavilion Gaming 15-ec2523nd" notebook that only shows a white power LED and doesnt respond to anything.
          After initial testing I concluded the bios seems to be corrupted since all voltages are normal and there are no shorts. HP has a feature for a bios restore from USB with winkey+B for this model. This did not work.
          I have desoldered the bios chip (GigaDevice...
          03-16-2024, 03:12 PM
        • JoWed
          Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
          by JoWed
          Hello Community,
          I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
          07-01-2025, 09:32 AM
        • studdy05
          Bricked HP Probook 450 G7 Bios questions
          by studdy05
          Hp Probook 450 G7 s# SCD0348W35 had a locked BIOS. Bought BIOS and EC chips off Ebay that were supposed to match this machine - the 450 G7. Flashed in the BIOS on chip i bought using a CH341. BIOS unlocked next boot. Some error to contact HP. Entered BIOS and reset to system defaults and rebooted. Machine worked fine but every cold boot the contact HP message popped and everything else worked as fine. Assumed the error was from EC chip not matching BIOS that i just flashed in. So i flashed in the EC that was supposed to match from the EBay chip i bought and instant brick.
          Ive got...
          07-08-2025, 09:24 PM
        • legendkray
          BIOS Help Regarding GM5IX7A-GM6IX7A Origin Laptop
          by legendkray
          I have OriginPC EON 15SL, however, my laptop starts and shutsdown after 1-2 second. Keyboard leds are coming on then fans spinning then it shutsdown and not turning back on unless I plug out the power cable and plug it in. I had issues with bricked BIOS then I flashed BIOS I got from the vendor to the SPI chip and still it didn’t worked because my EC firmware was newer than the BIOS I have flashed. So I wanted to try flashing the EC chip with the correct firmware that matches with the BIOS also from the vendor and it worked everything was well, and then stupid me wanted to unlock some...
          07-05-2025, 09:25 AM
        • AquaMan Ua
          by AquaMan Ua
          05-17-2025, 09:40 AM
