hp dv7-1183cl bios needed
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Please I need working bios for HP DV7-1183CL thanks in advance
  • String2016
    • Nov 2015
    • 2242
    • philippines
    Re: hp dv7-1183cl bios needed
    Please help thanks in advance
    • String2016
      • Nov 2015
      • 2242
      • philippines
      anyone please help
      • imranromi
        • Jan 2015
        • 1291
        • Pakistan
        Send board id.
        • String2016
          • Nov 2015
          • 2242
          • philippines
          Board id:E1 JAK00 LA-4082P REV1.0
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            check this , depending your DV7 type is DV7-1000 series,
            https://www.badcaps.net/forum/showthread.php?t=48109
            same update file sp51315.exe ( there is 3 type of *.FD file) But you must trying what exactly for your mobo
            • String2016
              • Nov 2015
              • 2242
              • philippines
              Ok thanks but Ive recheck the voltage Ive notice that there is no 19v in the dc jack but when I Replace PL1 19v is present but there are no voltage on all mosfet and coil. Please help what should cause trouble for no voltage on the board. I have attached the image ifle Please help thanks in advance
              • String2016
                • Nov 2015
                • 2242
                • philippines
                Anybody please help
                • String2016
                  • Nov 2015
                  • 2242
                  • philippines
                  Anyone please help
                  • LP_tekh
                    • Oct 2015
                    • 95
                    • Laos
                    I'd experienced this in dv6000, no voltages at all. i just thought internal problem.
                    I think laptop board has 6 layers of copper plate, may be internal problem.
                    • String2016
                      • Nov 2015
                      • 2242
                      • philippines
                      How did you solve it?
                      • LP_tekh
                        • Oct 2015
                        • 95
                        • Laos
                        I did not. I told to my client that the problem was the system board and to be replace with a new one, my client agreed so i did.
                        Don't waste your time like i did, almost changed everything, still nothing.
                        • String2016
                          • Nov 2015
                          • 2242
                          • philippines
                          You are correct ive changed everything shorted and change maxim ic still the same this board is hard to fix thats why ive told also the client to replace the board my client also agree i spend 2days fixing this board what a waste of time
                          • Chieftain
                            • May 2016
                            • 72
                            • Greece
                            Here a bin for your DV7 LA-4082p Rev1 . (With Core2duo and Nvidia VGA)
                            • arb_com
                              • Aug 2018
                              • luxor
                              Not work
