hp 15-an050nr bios
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    hp 15-an050nr bios
    Could really use help getting this dump DAX1BDMB6F0 REV:F
  • bluestone
    • Jun 2011
    • 343
    • Ghana
    Re: hp 15-an050nr bios
    I have been able to extract the file from hp original execution file with all the different BID numbers. Could be of use to someone. all are 100% working.
    • Gobbla
      • Mar 2015
      • 27
      • United Kingdom
      how to remove manufacture mode is in unlock mode ?
      080a0 tested ok but got that stupid message :/
      thx
        • 22109
        thx
        Try this
        • Gobbla
          • Mar 2015
          • 27
          • United Kingdom
          thx !!! finally mystery solved
          • Duvelhedz
            • Oct 2015
            • 20
            • United Kingdom
            Here is a DAOAX2MB6F0 dump which I have set a new Intel ME section. Flash and go. BIOS is in chinese. Just change the language in the BIOS settings. I could not find a recent enough version of the DMI tool to set the serial. This BIOS has a serial number on it.
            • nsilvang
              • Mar 2017
              • 26
              • mexico
              duvelhedz it works your dump thanks
              • nhutvhe
                • Jul 2016
                • 9
                • Viet Nam
                file good thanks!
                • saadi
                  • Oct 2015
                  • pakistan
                  it works fine thanks
                  • jasko_jacker
                    • Oct 2014
                    • 1140
                    • italy
                    How to identify the correct version without an original dump ?
                      • 22109
                      EDIT: wrong info.
                      • jasko_jacker
                        • Oct 2014
                        • 1140
                        • italy
                        Help to identify correct bios
                        Hp star war edition DAX1BDMB6F0 REV:F
                        080A0 fan spin but cpu cold
                        080A9 fan reapeatly stop and go but cpu cold
                        0809B fan not spin cpu cold
                        08092 fan spin but cpu cold
                        • imranromi
                          • Jan 2015
                          • 1290
                          • Pakistan
                          You can try all bios you know which is original if work your laptop.Different bid is not work i experience same hp laptop same not know what bid is original board i try all 1 by 1 then 1 bid work for me.
                            • 22109
                            EDIT: 80A0 is the correct Bios i5-xxxxU ,i7-xxxxU Skylake U
                            • Nova10
                              • Feb 2019
                              • 11
                              • Österreich
                              • jasko_jacker
                                • Oct 2014
                                • 1140
                                • italy
                                intel i7-6500u SR2EZ
                                I would like to be sure of the bios before starting a search for a hardware problem
                                  • 22109
                                  Yes, 080A0 is the right one.Ive added a screenshot of the platform.ini file from the bios update.
                                  The schematic is posted on another thread: https://www.badcaps.net/forum/showthread.php?t=73893
                                  • jasko_jacker
                                    • Oct 2014
                                    • 1140
                                    • italy
                                      • 22109
                                      You`re welcome .
                                      • essaadi
                                        • May 2016
                                        • 52
                                        • MOROCCO
                                        Thank you brothers
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • cr4zychriss
                                          by cr4zychriss
                                          • Rebrand: PC Specialist
                                          Yesterday, 04:04 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                        • Vesko356
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
