DAX1BDMB6F0 Powerup Issue
  • BarNiy
    • Dec 2018
    • 3
    Mainboard of HP Pavillon 17-g105ng (i5 and geforce 940M)
    The Mainboard is called: DAX1BDMB6F0 REF:F MODEL: X1BD
    Here is a Thread with a similar Mainboard: https://www.badcaps.net/forum/showthread.php?t=70410 there are schematics linked. I did the Measurements suggested in the Thread:
    Coil-Measurements with Power-supply attached and Battery:
    A = PL8 = Battery charge Vage (+BATCHG) = 1.4 V
    B = PL16 = CPU graphics (+VCCGT) = 0 V
    C = PL14 = CPU core (+VCC_CORE) = 0 V
    D = PL12 = CPU system agent (+VCCSA) = 0 V
    E = PL13 = Deep Suspend rail (+1.0V_DEEP_SUS) = 1.04 V
    F = PL11 = 5V rail (+5VS5) = 5.06 V
    G = PL17 = 3V rail (+3VS5) = 3.35 V
    Coil-Measurements with only the Battery:
    A = PL8 = Battery charge Vage (+BATCHG) = 16.23 V
    Coil-Measurements with only the PowerSupply:
    A = PL8 = Battery charge Vage (+BATCHG) = 0.22 V
    on the ITE-IC:
    pin 119 (RSMRST#) = 0 V
    pin 107 (NBSWON1#) = 3.28 V (Measured at the ? on my attachment) on PwrButtonpress gets pulled down to 0.29 V
    pin 89 (SLP_SUS_ON) = couldn't find a point to measure (My Probes are too thick to measure directly on the pin)
    pin 87 (DSWROK_EC) = couldn't find a point to measure (My Probes are too thick to measure directly on the pin)
    Firmware chip pin 8 (+3V_DEEP_SUS) = 0.08 V
    - 1.8V regulator output inductor (+1.8V_DEEP_SUS) = 0.0 V
    Ordered some needle probes, but that will take some time till they are here.
    Hopefully someone can point me to where to find the error -- or provide a diagram where to measure.
  • on/off
    • Oct 2016
    • 333
    • Indonesia
    Re: DAX1BDMB6F0 Powerup Issue
    Currently the boardview (BV) not available.
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      first, reprogram EC and Bios to see what will happen.
      • BarNiy
        • Dec 2018
        • 3
        Why reprogram? Are they known to loose their programming?
        Wouldn't it be more useful to measure the boot-up sequence?
        If someone could point me to the testpoints, I guess I could get the readings and locate the error.
        And how do I reprogram the EC?... ^^
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Why programming--- yes bios does gets corrupt and thats why more than 80% posts here are for bios requests only. You are not getting 3v on pin8 of bios which should be present before powering up in this mb as per some other posts in our forum. So no harm in trying bios reflash first.
          For kbc you need special programmer like svod etc.
            • 22093
            Schematic .
            • piernov
              • Jan 2016
              • 4439
              • France
              RSMRST# is missing. It comes from the EC. So either a signal prior to it in the power sequence is missing, or there is an issue with the EC itself.
              Issue with the EC can be that it's damaged or the firmware is corrupted so that's why you were suggested to try to flash it.
              Unfortunately on this platform the EC firmware is embedded inside the EC itself so you'd need a special programmer for that as @mcplslg123 said.
              However in this case you're missing +3V_DEEP_SUS, which is enabled by SLP_SUS_ON (see U5) which comes from the EC as well (and is required for RSMRST# to come up). For SLP_SUS_ON to come up, the SLP_SUS# signal from the PCH has to come up before. You need to measure both those signals, they are a critical part of the power sequence.
              I note that you have +1.0V_DEEP_SUS, but schematics is a bit confusing around PU12 so it may well have been reworked later in the design process, so we can't assume anything with this information.
              Also please try to measure the power rails and signals you measured when pressing the power button to see if anything changes
              • on/off
                • Oct 2016
                • 333
                • Indonesia
                Just found BV on mega. This BV for X1A not X1BD, I knew would different, but i think there are 70% have similarities.
                Just for compare and reference only, since Quanta have no label component on PCB (newest quanta)
                • BlueMidnight
                  • Jan 2015
                  • 489
                  All three of the Deep Sx power rails are activated by SLP_SUS_ON. However, you've only measured one of them (+1.0_DEEP_SUS) as being the correct voltage.
                  Measure the pins of the related ICs to see what is happening:
                  PU12 for +1.0_DEEP_SUS
                  PU15 for +1.8V_DEEP_SUS
                  U6 for +3V_DEEP_SUS
                  For example, if you get SLP_SUS_ON at PU12, but not PU15 or U6, then perhaps there is a broken via somewhere on the board.
                  Note: When you see an asterisk next to a part in a schematic, it usually means that part is not installed on the production version of the board. So, you can consider it an open circuit. But, parts such as the 0 ohm resistors and jumper near PU12 have actually been replaced by solid traces. The markings are still on the board, but you'll find that the pads have been joined together into one big rectangle underneath the solder mask.
                  You can absolutely use the X1A boardview for a lot of things on this board. However, many of the part IDs are different. You will need the X1A schematic to cross-reference them. (e.g. On the X1A, PU15 is named PU14 and U6 is named U5)
                  • dalejg
                    • Dec 2019
                    • 10
                    Did you ever find the fault on this motherboard as to why it is not starting up. I am having the same problem.
                    • siroos_tz
                      • Feb 2014
                      • 121
                      • the UK
                      Originally posted by SMDFlea
                      Schematic .
                      • siroos_tz
                        • Feb 2014
                        • 121
                        • the UK
                        • shahnld
                          • Nov 2019
                          • 164
                          • Netherlands
                          Good Day.
                          Does anyone got somewhere with +vccgt missing..? I have 4 laptops. 2x msi i7 7700hq. 2x dell i7 7700hq and 6700hq all missing +vccgt. Laptops goes on black screen.
                          • Nagy Daniel
                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                            by Nagy Daniel
                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                            So, I generated a table with AI so I can...
                            03-04-2025, 08:24 AM
                          • Victor Moreira Silva
                            Acer Nitro 5 LA-L181p power LED turns on by 5 secs (Short on PCH rail?)
                            by Victor Moreira Silva
                            I'm trying to repair my old Acer Nitro 5 (AN517-54-55T5). I've already bought a new laptop, so this is more of a learning project. For the experience, with no high expectations of success.
                            Well, my decice specs are the following:
                            Model: Acer Nitro 5 AN517-54-55T5
                            CPU: Intel Core i5-11400H
                            GPU: NVIDIA GeForce GTX 1650
                            Motherboard: GH51G LA-L181P Rev:1c
                            The symptom:
                            When pressing the power button, the power LED lights up for about 5 seconds and then turns off. Initially, the issue was intermittent: sometimes...
                            05-26-2025, 10:49 AM
                          • lefetylorant
                            Lenovo Thinkcentre tiny M90Q gen 1 - no 12V rail
                            by lefetylorant
                            Hello Everyone,
                            Long story short, I got this unit for very cheap.
                            I've started to experiment with it's BIOS, as I did before successfully with an M900. However my very bad quality SOIC clip broken while dumping of the biosof and it must have damaged something on the panel, because it does not turn on, and does exactly nothing when powered. The maximum voltage that could have affected something is the 3.3 or 5v from the IC clip, because the unit was not powered while the bios dumping was in progress.
                            I've performed some measurements:
                            - 20V rail perfectly...
                            09-14-2023, 05:05 AM
                          • bimole
                            Weird behavior on 3.3V rail of a CORSAIR CX600
                            by bimole
                            A colleague gave me an apparently ill CORSAIR CX600.
                            He told me that he heard a banging noise, and smelt the magic smoke.
                            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                            It's another story on the 3.3V rail...
                            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                            02-13-2025, 04:49 AM
                          • mkdj
                            Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                            by mkdj
                            Dear all,
                            I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                            I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                            Both N-Channel Mosfets: nothing odd
                            P-Channel MOSFET number 1:
                            source - drain : 117 kOhm
                            source - gate: 96 Ohm
                            gate - drain: 117 kOhm
                            P-Channel MOSFET...
                            08-20-2025, 06:08 AM
