Bios for Asus K75VM need. Thank
  • Fabbrone
    • Jun 2015
    • 158
    • italy
    Hy, I am looking for a dump bios for this notebook Asus K75VM.
    Fabrizio
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: Bios for Asus K75VM need. Thank
    IT's from asus web site
    • G33RT
      • Oct 2016
      • 69
      • Belgium
      @Fabbrone
      I know it's an very old post but yet I want to help.
      Do you still need that bios dump ?
      Regards, Geert
      • samstown
        • Mar 2021
        • 122
        • Switzerland
        Here is another one that worked for me.
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Anchar777
          ASUS P1412CE need BIOS DUMP
          by Anchar777
          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
          06-26-2025, 03:39 AM
