Dell 3537 LA9982p KB9012
  • ahsi19
    • Jul 2016
    • 28
    • egypt
  • hyditech
    • Jun 2012
    • 272
    • nigeria
    Re: Dell 3537 LA9982p KB9012
    Thanks bro
    • dspok
      • Jan 2014
      • 553
      • Nepal
      Thank you.
      • sherifbekhit
        • Feb 2017
        • 19
        • alex
        Thank you too much
        • samanthban
          • Feb 2014
          • 253
          • Sri lanka
          Thanks ahsi19 tested and work 100%
          sigpic
          • Bowline
            by Bowline
            06-11-2025, 10:13 AM
          • Calidebear
            Dell 3537 laptop doesn't boot without embedded display.
            by Calidebear
            I have this laptop for a long time, still it does it's job, like browsing, word , excel. Two years back laptop Hinge base broken but now it's damaging other parts of laptop so I tried to totally remove the embedded display cable from laptop and tried to boot only with external display monitor, but it doesn't boot and gives single beeps. BIOS checking the embedded display to be connected.
            So checked the schematics to bypass this issue.
            Found something but I don't know how to read this schematics.
            Dell 3537 mobo 9982p rev 3
            Schematics attached,...
            03-29-2025, 11:37 AM
          • Akhlz001
            by Akhlz001
            09-20-2025, 07:15 PM
          • master3112
            by master3112
            07-29-2025, 01:55 PM
          • rddube
            Dell 15-3537 motherboard part identification
            by rddube
            Trying to identify the following part J7 FL M1R in the photo which is on one of the power circuits on a Dell 15-3537 motherboard. Went through the SMD code manual but couldn't find it and google doesn't either.
            Help please and thank you
            02-27-2024, 09:50 PM
