New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
hi...all
I got one laptop from one customer, and he forgot the BIOS password. I removed the BIOS chip from MB and with the help of a programmer reprogrammed it. After powered on I found the system is still asking BIOS password. I thought the programming was failed, and I again erased the chip and again reprogrammed it. I am sure that I completely erased the chip before programming. I friend told me there is another BIOS program embedded is IO chip.
system is asking "ENTER CURRENT PASSWORD" (checked without HDD )
I don't know what to do.Kindly help me
hi...all
Bios password is on kbc,so you need to erase and re-program it with programmer like Svod or something similar.
Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
Agradeço imensamente a qualquer um que possa me ajudar. Procurei por alguns dias, mas todo mundo está cobrando para fornecer as senhas. Obrigado novamente!
Por favor, gere uma senha para mim?
English - I would really appreciate it if anyone could help me. I've been searching for a few days, but everyone is asking for passwords. Thanks again! Can you please generate a password for me?
DELL Inspiron 5547
Sistema Desativar: 7C49F8BC5A8715FE
Serviço Tag: GJGBK22
DELL Inspiron 5547
I appreciate it immensely to anyone who can help me out. I've searched for a couple days, but everyone is charging to give out the passwords.Thanks again! Please generate a password for me?
When the PC is starting I press F2 and it goes to the bios screen
I go to:
Boot menu > Security > Locked Setup
in Locked Setup
I unlock Setup, I got the password wrong 3 times to generate it again, the following appeared:
System Disable 60EE01A3D674BE5A
Service Tag GJGBK22
My problem is the locked Setup password, my PC turns on normally, without asking for a password. I need the master password to be able to change the boot from legacy to UEFI
Seems like this model uses System Disable 16-hex code
hi...
i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
i updated to latest version and try other version but not working!
service tag: HCQ3JW2
i need your kind....
looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
cheers
Attached;
1. My saved bios using a programmer
2. Dells Bios updater .exe (v1.16)
3. Dells Bios recovery file
4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
5. Image of ME...
I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
