asus r752m bios dump
  • asliyucegsm
    • Jun 2011
    • 347
    • Turkiye
    my friend
    asus R752M
    intel bay trial quad-core 3530.up to 2.58ghz
    mainboard
    x751md mainboard
    rev.2.0
    ite 8985e
    1417-axa
    25q64
    bios dump
    thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: asus r752m bios dump
    read old bios and post it here
    Im Back... sort of...
    • highpulse
      i hate HP
      • May 2013
      • 1488
      • portugal
      here it is
      • asliyucegsm
        • Jun 2011
        • 347
        • Turkiye
        USB ports do not work with any other file
        • Pascal Komlassan
          • Jan 2017
          • 806
          • TOGO
          Originally posted by highpulse
          here it is
          thanks bro
          • kalisko
            • May 2016
            • 45
            • Serbia
            Maybe someone needs it
            100 % OK
            • superdtech
              • Feb 2020
              • 15
              • Ivory coast
              • razor_amd
                by razor_amd
                12-15-2020, 07:07 PM
              • DynaxSC
                by DynaxSC
                06-14-2024, 03:49 PM
              • jbonavita
                by jbonavita
                Some issues
                Things I tried
                04-29-2025, 09:38 PM
              • Habble7
                by Habble7
                Suspected Cause:
                Troubleshooting Attempts:
                05-22-2025, 07:28 AM
              • Anchar777
                ASUS P1412CE need BIOS DUMP
                by Anchar777
                Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                06-26-2025, 03:39 AM
