Failed bios flash
+ More Options
Posts
  • newtothis
    • Mar 2013
    • 1556
    • england
    Failed bios flash
    Ok so have a laptop coming to me that has a failed bios flash - The system hung and the owner powered the system down - Upon trying to boot the system lights up but no display/backlights etc....
    So I could buy another bios and solder it on but where is the fun in that...
    I have a raspberry PI that I use to flash the NOR chipsets on playstation 4 when they go corrupt... I have a SOIC 16 to DIP 16 jig for the PS4 NORs and the laptops is a SOIC 8 so I should be able to fit it in..
    So my question as I have never done a laptop BIOS before... Can I just get the BIOS files from the manufacturers website and reflash it via my PI or does it have to be a full dump of an existing BIOS?
    Cheers
    • 30977
    Re: Failed bios flash
    depends on the size of the bios download vs the chip
    • newtothis
      • Mar 2013
      • 1556
      • england
      With that I am assuming there are usually containers associated with the bios downloads from the manufacturers websites vs the RAW data on the chip?
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        usually but not always
        when you get laptop, post full model code, motherboard model and il try to help
        Im Back... sort of...
        • newtothis
          • Mar 2013
          • 1556
          • england
          I know the model of the system is a MSI GE60 2PC-610UK
          I will get board numbers once in my possession.
          • newtothis
            • Mar 2013
            • 1556
            • england
            Ok so I get the laptop in - Open her up and guess what I find....
            plenty of this over a lot of the board
            I very much doubt what the owner said was true - Seems liquid killed this one
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              Bust out the IPA and toothbrush then.
              A working TV? How boring!
              • newtothis
                • Mar 2013
                • 1556
                • england
                Already scrubbed the board down.. No change
                No heat from GPU
                CPU gets BURNING hot
                No Backlight
                No display
                No sound
                Charge and power light work
                Fan Works
                That is all - May sell as liquid damaged on eBay but otherwise scrap heap
                  by Vesko356
                  08-11-2023, 03:27 AM
                • abhorsen
                  Help Disabling Flash Protection Range Registers on Lenovo P360 Tiny BIOS
                  by abhorsen
                  Hey guys,
                  Hope you all are doing well. I come here from Win-Raid because I am having issues disabling Flash Protection Range Registers so I can flash my BIOS from within Windows using Intel's IFW tool/using flashrom within Linux, however I cannot due to the above mentioned error.
                  Here is my thread on Win-Raid detailing the whole process I went through: https://winraid.level1techs.com/t/re...h-gen/95478/27
                  Essentially I managed to boot into Windows while shorting PINs 1+5 of my audio chip to disable the HAP bit...
                  07-06-2023, 10:22 AM
                • mrrubik
                  Dell Optiplex 7010 micro bad BIOS flash?
                  by mrrubik
                  Hi folks,
                  I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
                  After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
                  Steps I took:
                  1. Read BIOS with CH341a, verified hash twice
                  2. Patched
                  12-23-2024, 04:11 PM
                • AkaBukai
                  Is it okay to flash stock bios onto the motherboard's BIOS?
                  by AkaBukai
                  Hi there,
                  I have a 14" Lenovo Laptop (Flex 5 14ALC05) which has a boot issue.
                  The little LED on the power button is flashing slowly and nothing happen.
                  This unit do not have any BIOS button cell battery so I tried many times draining the power but it is still not powering on.
                  So I decided to flash the BIOS using a cheap programmer.
                  And I was successfully able to read the content (exactly 16MB file) which BTW is a WINBOND 74m12jwsiq (according to the package inscription - but detected as W25Q128FW in the software - IMSProg on Linux)
                  I also...
                  12-19-2024, 12:15 PM
                • James Jackson
                  Panasonic CF-20G0247VM BIOS Bad Flash Help
                  by James Jackson
                  I usually try to figure these things out on my own but am asking for help now as I have been beating my head against a wall.
                  Backstory, I initially ended up with a CF20 Mk2 with a locked BIOS. I used aptio to read the BIOS and made the adjustments to the .rom file and attempted to write it back with aptio before reading other users problems with that setup. Well it bricked the BIOS go figure. Computer no longer boots, black screen. I found a clean BIOS on this forum but now I am having ME issues. So I would rather hand over the aptio dump(pre BIOS brick) and a hardware reader dump(post...
                  05-01-2025, 11:28 AM
