Dell Inspiron 15R-5537 Bios Password
  • mazloum
    • Sep 2012
    • 504
    • Lebanon
    hi
    is there a way to reset the bios password of dell inspiron 15r-5537
    its service tag is new one and doesnot end with -595b or others
    thanks
  • niggi
    • May 2016
    • 208
    • UAE
    Re: dell inspiron 15r-5537
    try this bios
    • niggi
      • May 2016
      • 208
      • UAE
      hi try this bios
      • raajkumar
        • Mar 2015
        • 354
        • Srilanka
        I forgot the password for Dell Inspiron 15R-5537 Laptop. It's Service Tag is : 4G5RQY1. Anyone can give the master password for this.
        • crazykill
          • Jun 2016
          • 11
          • Bulgaria
          Re: Dell Inspiron 15R-5537 Bios Password
          Try these 6020005,70obi6r9,d5gdrcut,7zp4GKrG9syFZN7w.
          • raajkumar
            • Mar 2015
            • 354
            • Srilanka
            It shows System disabled " BFD405093B291DF0 " and service tag " 4G5RQY1 " after i put your codes
            • niggi
              • May 2016
              • 208
              • UAE
              hi try this bios
              • raajkumar
                • Mar 2015
                • 354
                • Srilanka
                I flashed the bios with the new dump. but still it ask the password.
                • rioreno
                  • Feb 2009
                  • 540
                  • Indonesia
                  try this, working dump
                  • raajkumar
                    • Mar 2015
                    • 354
                    • Srilanka
                    Thanks for your file. But after i flashed with your file, Laptop not starting and it switch off again after 2 seconds.
                    • raajkumar
                      • Mar 2015
                      • 354
                      • Srilanka
                      Need Dell 15R 5537 EC+Main Bios. Its having password on io controller
                      • rioreno
                        • Feb 2009
                        • 540
                        • Indonesia
                        when you flashing with niggi file, is ppid and servicetag still same displaying with your original ppid/servicetag? if that happen, yes your password is stored at kb9012 ... i try to trace for niggi file, cannot found servicetag/ppid...
                        this is kb9012 files maybe fit for your board...
                        you can compare with your backup original kb9012, before flash..
                        for main bios i think, you can use niggi file
                        fyi: you can get ppid and service tag this kb9012 with hexeditor at 1E000 address...
                        • raajkumar
                          • Mar 2015
                          • 354
                          • Srilanka
                          Thanks RIORENO. My programmer ( TL866CS ) doesn't support to do KB9012. I just ordered for RT809F Programmer, and it will reach me within 15 days. I will get back to you soon.
                          • razadom
                            • Apr 2015
                            • 105
                            • Madagascar
                            Hello RIORENO
                            can you show me how to retrieve password from dump of super IO KB9012. I want to
                            dump flash from IO with CH341 programmer. It seems that activate EDI on this superIO can access directly embedded SPI.
                            • raajkumar
                              • Mar 2015
                              • 354
                              • Srilanka
                              I done this password clearing with RT809f programmer successfully. Thanks for all support in this thread
                              • nataf10
                                • Mar 2012
                                • 37
                                • Israel
                                Hello there,
                                I'm trying to repair a Dell laptop with a Bios Issue.
                                I downloaded the file you have post on May 2016 and flash the bios chip with my external programmer (TL866CS)
                                Unfortunately it didn't solved my problem.
                                I'm convinced that the bios is corrupted,the Laptop is turn on and the fan is spinnig, the screen is BLACK and I hear 2 beeps one is loud and the next is low.(repeatedly).
                                The model is DELL 15R-5537
                                MotherBoard model VBW01 LA-9982P, REV 3.0(A02)
                                Do you have another bios file that you took out from a working motherboard?
                                Or do you have any ideas for my symptom?.
                                Thank you very much for your time and help
                                • bhcomputadores
                                  • Jun 2017
                                  • 25
                                  • Brazil
                                  Thanx a lot!
                                  • Marlon MK
                                    • Mar 2018
                                    • Brasil
                                    I am having the same password problem on bios. But I do not have the bios burner .... I would like to edit the Bin file and flash it through Insydeflash.
                                    If anyone already has the file and share thank you.
                                    Hug to everyone.
                                    • chitaaldaa55
                                      • Nov 2019
                                      • Mongolia
                                      • Ghamidi
                                        • Mar 2020
                                        • 306
                                        • France
                                        need password Inspiron 15R 5537
                                        hello
                                        please need password dell Inspiron 15R 5537
                                        System disable : 2DE90579CE1B2571
                                        Service tag : 6113502
                                        thank you
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • Godfather79
                                          Dell Latitude 5520 3FE2 Bios password Unlock Request (TGL SuothPeak15)
                                          by Godfather79
                                          Hello everyone in the community
                                          Dear Sir,
                                          I need help removing/unlocking the BIOS Service Tag password on my Dell Latitude 5520 laptop.
                                          Problem details:
                                          * Model: Dell Latitude 5520.
                                          * Board ID (from BIOS file): TGL MB 8L 19819-1 (Southpeak15).
                                          * Required Password Code: 3FE2 (BIOS Service Tag Lockout Code).
                                          * Service Tag: (Enter your actual Service Tag from the laptop here)
                                          * ​BIOS Status: I successfully modded the BIOS file and created FINAL_CLEANED_ME.bin (32MB) with a clean ME region (CSME 15.0), because the original dump was corrupt....
                                          Today, 10:04 AM
                                        • tariom18m
                                          Dell inspiron 5415 bios Password
                                          by tariom18m
                                          Dell Vostro 5415 bios Password MOD EDIT: INSPIRON 5415 NOT VOSTRO
                                          Hi could anybody help me with removing bios password please or supply clean me bios for Dell Vostro 5414 MOD EDIT: INSPIRON 5415 NOT VOSTRO
                                          Système disable
                                          5B8336EF14B92F31
                                          SERVICE TAG
                                          5ZYRHG3
                                          Thanks in advance
                                          10-23-2023, 01:05 PM
                                        • sahamipoor
                                          need bios dell Inspiron 17 7000 2-in-1 p42e
                                          by sahamipoor
                                          hi...
                                          i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                                          i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                                          i updated to latest version and try other version but not working!
                                          service tag: HCQ3JW2
                                          i need your kind....
                                          10-01-2025, 11:10 AM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
