BIOS DUMP FOR ASUS x16s , urgent !
  • bestdan50
    • Aug 2015
    • 170
    • nigeria
  • bestdan50
    • Aug 2015
    • 170
    • nigeria
    Re: BIOS DUMP FOR ASUS x16s , urgent !
    • ala_borbe
      aka Donald
      • 1625
      • Malta
      read old bios and post here
      Im Back... sort of...
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        I think that he mixed a little bit :
        https://www.badcaps.net/forum/showthread.php?t=54751
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Anchar777
          ASUS P1412CE need BIOS DUMP
          by Anchar777
          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
          06-26-2025, 03:39 AM
