i need dell inspiron 17-3721 bios plz
  • niggi
    • May 2016
    • 208
    • UAE
    i need dell inspiron 17-3721 bios M/B VAW11 LA-9102P REV 1.0 (A00)
  • ridamouh159
    • Nov 2014
    • 365
    • maroc
    Re: i need dell inspiron 17-3721 bios plz
    here is your bios
    • niggi
      • May 2016
      • 208
      • UAE
      thanks u so much bios is working ok bios 100%
      • djamel1986
        • Jan 2015
        • 10
        • algerie
        thanks
        • newnoob
          • Sep 2016
          • 18
          • Italy
          thank's man
          • cpuprices
            • Jan 2014
            • usa
            Yes what they said and then some. It is always good to meet someone with skillz. I doubt there is much I can do for you but if I can let me know. I solder down to the size of this period. I have some experience with data recovery, very odd repairs to very odd size LCD panels, as well as repair of industrial controls and systems, logic boards, motherbords, PCBs and more. Lets just says I have been around the block. I am in Portland Oregon, but there is always tips and tricks to share anyway have a GREAT YEAR.
            • babu78
              • Jun 2017
              • 8
              • tbilissi
              thank's man
              • tota7
                • Feb 2017
                • 15
                • ISRAEL
                first thank you very much its work, and boot fast
                second its was 1 BEEP error code, and bios flash solved the problem
                • 3xdan
                  • 5
                  • romania
                  Hello
                  is also valid for inspiron 17-3721 bios M/B VAW10 LA-9105P REV 1.0 (A00) ?
                  thank you in advance
                  • 3xdan
                    • 5
                    • romania
                    I found.....
                    if he needs to
                    anyone ...
                    works 100%
                    tested on: inspiron 3721 mainboard VAW10 LA-9105P REV:1.0 (A00)
                    • Techtiger
                      • Oct 2014
                      • 1602
                      • france
                      Originally posted by ridamouh159
                      here is your bios
                      thanks for the BIOS WORKING
                      • gbaicu51
                        • Feb 2015
                        • 29
                        here is your bios
                        Many thanks for the files . can you tell me please where is located the chip on the MB ? just bought a cheap programer from ebay and i try to fix my friend laptop . 1 bep error code
                        • gbaicu51
                          • Feb 2015
                          • 29
                          tried the files on my dell 17 3721 , but i get error file size larger than IC size
                          any ideea please ? my mobo is vaw10-ls9104p . EC.bin is ok but chip.bin i get that error . thanks
                          • andrew25
                            • Feb 2016
                            • 224
                            • Malawi
                            thanks so much... it worked
                            • fatih
                              • Apr 2017
                              • 17
                              • turkey
                              thank you very much
                              • ABDO26
                                • Jul 2019
                                • 14
                                • medea
                                thank you very much
                                • Silver1983
                                  • Sep 2020
                                  • 5
                                  • greece
                                  What is the type of ic must choose on programmer for flash bios?
                                  Also can we flash it with wire clamp or must dessoldering from motherboard?
                                  Thanks in advance!!!
                                  • Bilal@pc
                                    • Jun 2021
                                    • 44
                                    • Algeria
                                    thank you very much it work
                                    • cavalierks
                                      • Feb 2018
                                      • 20
                                      • ALGERIA
                                      i need dell inspiron 17-3721 bios please
                                      i have try one file but always ask password ​
                                        • 21936
                                        Type and post the service tag
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • sahamipoor
                                          need bios dell Inspiron 17 7000 2-in-1 p42e
                                          by sahamipoor
                                          hi...
                                          i need bios of dell Inspiron 17 7000 2-in-1 p42e by chassis Jedi 15/17 cml-mb 18806-1.no display by bios issue.
                                          i used and flashed ( dell Inspiron 17 7591) by same chassis and worked .but TMP not detect showing. and not enabling in bios(after each reset disable again). Most importantly the booting up display and startup bios (before windows loading) is too many slow!
                                          i updated to latest version and try other version but not working!
                                          service tag: HCQ3JW2
                                          i need your kind....
                                          10-01-2025, 11:10 AM
                                        • zlr8r
                                          looking for fully extracted by programmer Bios for a Dell Inspiron 17 (7786)
                                          by zlr8r
                                          looking for a fully extracted (by programmer) Bios for a Dell Inspiron 17 (7786) v.1.09 or newer, so I can compare it with my own bios to check for corruption.
                                          cheers
                                          Dell Inspiron 17 (7786) Laptop
                                          Service Tag: 5J0NHT2
                                          Bios: 1.9.0
                                          MOBO: RO 15 17 WHL 2GB MB / 18706-2
                                          Attached;
                                          1. My saved bios using a programmer
                                          2. Dells Bios updater .exe (v1.16)
                                          3. Dells Bios recovery file
                                          4. What I got when i tried to extract the main bios .bin file from Dells Bios v1.16 exe/rcv using some .py script i found online.
                                          5. Image of ME...
                                          12-18-2023, 03:08 PM
                                        • mikeybass
                                          by mikeybass
                                          04-23-2025, 04:30 PM
                                        • GadgetsFix
                                          Dell Inspiron 16 5630 BIOS request
                                          by GadgetsFix
                                          I'm in need of a BIOS file for a Dell Inspiron 16 5630. Unfortunately, I don't have access to the original BIOS file as this is for a replacement BIOS chip installation.
                                          • Model: Dell Inspiron 16 5630
                                          • MainBoard Part Number: 4550SC01C004
                                          • Laptop Serial No: GKH3JX3
                                          • DP/N: 0303KM
                                          • QUAKE N RPL UMA CS MB
                                          • 213251-2
                                          • TMN0H$KB
                                          01-17-2025, 07:38 AM
