Dell 5559 bios
  • punkrockpax
    replied
    Re: Please Someone Can Clean ME for this Bios?
    Originally posted by peste
    change the bios chip..
    you think is the BIOS chip? ive flashed the bios a few times trying some ME versions, mine is 11.5.XXXX if i use 11.8 still works but as kalilinux say it happens again, in the otherhand it was running slow even when ive installed a SSD, im guessing this issue can be causes for a BAD pch or CPU... i mean this happens often in macbooks with the same CPU architecture... so maybe we will have near future failing cpu chips
  • tdelfy
    replied
    Re: Dell 5559 bios
    new 1000% ok
  • kalilinux25
    replied
    W25Q128FVSIQ was the original I only have a W25Q128FVSIG but when I try to flash and put it on the board it wont power
  • peste
    replied
    Originally posted by kalilinux25
    good day sir after 2 days unit got the same problem again no display fans spin very loud
  • kalilinux25
    replied
    try
  • kalilinux25
    replied
    try
    'YOUR THE BEST a
  • peste
    replied
    BOARD: AAL15 LA-D071P REV 1.0 2015-07-06
    LAPTOP MODEL: Inspiron 5559
    NO GFX INTEL ONLY
    PROBLEM: Sometimes it will power on and other day not using it wont power it will just turn of maybe I ll try the bios Thanks in advance
    OLD BIOS attacehd:
    try
  • kalilinux25
    replied
    Originally posted by shabi
    use this
    fan turns so fast no dispplay
  • shabi
    replied
    use this
  • kalilinux25
    replied
    Please Someone Can Clean ME for this LA-D071P Bios?
    NO GFX INTEL ONLY
    OLD BIOS attacehd:
    Last edited by SMDFlea; 02-27-2021, 08:39 AM. Reason: Added LA-D071P to generic thread title
  • baiceanu_stefan
    replied
    Re: Dell 5559 bios
    Originally posted by nahi
    i solved my problem with this file.......
    tested working fine. Thank you!
  • peste
    replied
    Re: Dell 5559 bios
    Originally posted by ramrk
    this file using blank screen fan running fast help me please!
    post the original bios
  • ramrk
    replied
    Re: Dell 5559 bios
  • othinus123
    replied
    Re: Dell 5559 bios
    tks bro
  • techwizard
    replied
    Re: Dell 5559 bios
    Thank you very much you are a life saver
  • AlejoSchematic2020
    replied
    Re: Dell 5559 bios
    Thanks Full operation
  • Wahid Gul
    replied
    Re: Dell 5559 bios
    Thank you so much
    i check vinafix 10 bios no disply
    your bios work 100%
  • zedameo
    replied
    Re: Dell 5559 bios
    thank you
  • ricaik2005
    replied
    Re: Dell 5559 bios
  • Prabuth
    replied
    Re: Dell 5559 bios
    thanks its working.
  • zenius
    by zenius
    12-08-2024, 06:13 AM
  • mikeybass
    by mikeybass
    04-23-2025, 04:30 PM
  • jhanra
    by jhanra
    in windows 11 sound driver compatibility, but overall its ok, for me i can deal with it, 😅😅😅...
    11-02-2024, 04:19 AM
  • gizaha
    by gizaha
    02-13-2024, 07:18 AM
  • mrrubik
    Dell Optiplex 7010 micro bad BIOS flash?
    by mrrubik
    Hi folks,
    I got a Dell Optiplex 7010 micro PC (Exact Model) with 8FC8 BIOS and locked out admin password. I attempted to remove the password by patching the BIOS via info from this thread: https://www.badcaps.net/forum/troubl...ssword-patcher
    After flashing the patched the BIOS, the PC is unresponsive with a solid AMBER power LED (not documented in manual anywhere)
    Steps I took:
    1. Read BIOS with CH341a, verified hash twice
    2. Patched
    12-23-2024, 04:11 PM
