HP elitebook 8570p dump
  • teqcom
    • Nov 2015
    • 311
    • malasyia
    need bios
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: HP elitebook 8570p dump
    send board mobo number maybe some help.
    • alihomee
      • Dec 2012
      • 1576
      • malaysia
      plz need bios urgently
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        try this and reply.
        • alihomee
          • Dec 2012
          • 1576
          • malaysia
          thanks you very much but now i cant check laptop already take back by customer
          • nicoleluca300
            • Aug 2016
            • 67
            • france
            elitebook 8570p Bios need
            hi guys
            i need a bios of hp laptop elitebook 8570p core I5
            • Pascal Komlassan
              • Jan 2017
              • 809
              • TOGO
              Re: elitebook 8570p Bios need
              Your machine what problem?
              • nicoleluca300
                • Aug 2016
                • 67
                • france
                turn on but no diplay
                • polytek
                  • Dec 2013
                  • 496
                  • TUNISIA
                  Originally posted by nicoleluca300
                  hi guys
                  try this/
                  https://www.badcaps.net/forum/showpo...43&postcount=7
                  • ymaciejs
                    • May 2017
                    • U.K
                    Thanks you very much long time I was looking for dump BIOS to the Elitebook 8570p and we did it Confirmed the files correctly work ( to the write your dump I used MiniPro and work well and I`m happy because i can used my laptop without password to the BIOS. Thanks again
                    • mus
                      • Apr 2017
                      • 12
                      • france
                      • shahzeb
                        • May 2015
                        • 16
                        • Pakistan
                        thanks for uploading
                        • toufik sat
                          • Feb 2016
                          • 134
                          • los angles
                          • hussaka
                            • Jan 2015
                            • 152
                            • italy
                            thank you very much
                            • paratoner
                              • Feb 2020
                              • 19
                              • Turkey
                              Originally posted by imranromi
                              try this and reply.
                              Bro, I have the same problem with my HP Elitebook 8570p. It has got an admin password. I can't go into bios settings and can't change anything. How can I use this dump file? Thank you very much for all your help.
                              • peste
                                • 12887
                                • ROMANIA
                                you need a software programmer (ch341a, TL866A) ... remove the bios chip from the motherboard, make a copy, write the chip with the new bios, soldering the bios chip ... more information you can find on the internet ...
                                • paratoner
                                  • Feb 2020
                                  • 19
                                  • Turkey
                                  Why can't we do the reprogramming without removing the chip from the motherboard? There must be an easier way to do this.
                                    VIP Moderator
                                    • Aug 2018
                                    • 4386
                                    • Bulgaria 🇧🇬
                                    If you think there is another way, let us know what it is.
                                    If you want use SOIC clip, but best way is to program the chip out of the circuit. Desoldering the chip from the board is easy job, what would be the problem?
                                    Become a Badcaps supporter
                                    Thanks to all supporters.
                                    • RethoricalCheese
                                      • Mar 2013
                                      • 1518
                                      • Estonia
                                      Using soic clip is an easier method. But if you mean a software method then no, don't get that comfortable Passwords are there for a reason and they shouldn't be TOO easy to bypass.
                                        VIP Moderator
                                        • Aug 2018
                                        • 4386
                                        • Bulgaria 🇧🇬
                                        Originally posted by RethoricalCheese
                                        ...don't get that comfortable ...
                                        • Ahari
                                          by Ahari
                                          I...
                                          08-13-2025, 06:12 AM
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          💀 Problem:😅
                                          08-07-2025, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
