Need ASUS K56CM REV 2.0 bios
  • peste
    • Dec 2016
    • 13691
    • ROMANIA
    #41
    Re: Need ASUS K56CM REV 2.0 bios
    Originally posted by huss584
    Please some one help me to clear attached BIOS
    try..
    • Bartoloni
      • Jul 2018
      • 140
      • Italy
      #42
      Originally posted by kazia
      try this..
      very thank you it's working fine !
      • Bartoloni
        • Jul 2018
        • 140
        • Italy
        #43
        i'm using this dump on a S550CM (that uses the K56CM REV 2 board)
        but the bios version is 205 and latest from ASUS is 202
        everything seems working but after 30 minutes the computer is shutting down (probably intel management engine issue)
        any idea?
        • peste
          • Dec 2016
          • 13691
          • ROMANIA
          #44
          any idea?
          post the original bios of the laptop and pictures with the stickers in the memory area ram ..
          • whitevolf
            • Feb 2014
            • 124
            • TÜRKİYE
            #45
            thanks
            • kire_33
              Man_UTD
              • Apr 2014
              • 4
              • Macedonia
              #46
              Thanks, it worked
              • shutt1e
                • Nov 2015
                • 15
                • italy
                #47
                if someone still need it in 2024, this is a K56CA UMA only dump taken from a working machine. all bioses posted on this thread are for k56cm or k56cb
                • Costa287
                  • Oct 2023
                  • 7
                  • Minturno
                  #48
                  I'm working on the following machine:
                  • Model: Asus A56CB-XX175H
                  • Serial Number: D3N0CV25716912G
                  • Mainboard: K56CM Main Board REV. 2.0
                  • BIOS Chip: 25Q64FVSI6
                  I performed four separate BIOS dumps and compared them using WinMerge. All the files are identical. Problem Description:
                  The laptop behaves inconsistently:
                  1. Sometimes it powers on, but the screen stays black, with only the power LED and the power button lit.
                  2. Other times, it starts and works normally without any issues.
                  3. Occasionally, it powers on, the power and hard drive LEDs light up for a few seconds, and the numeric keypad LED turns on. Then, after a few seconds, the hard drive LED turns off, leaving only the power and numeric keypad LEDs lit.
                  4. In other cases, the screen remains black, but the laptop boots and displays output on an external monitor.
                  Notes:
                  • The machine works normally when it manages to boot successfully.
                  • The black screen issue tends to happen more often after the laptop has been without power for a while.
                  • The CMOS battery is new.
                  I've attached the BIOS dump for reference.
                  I'm hoping the issue is related to the BIOS, but if anyone has encountered this problem before, I'd greatly appreciate advice on how to proceed with the repair.
                  Thank you!
                  • volinakis
                    • Jan 2021
                    • 2874
                    • N/A
                    #49
                    try celan_ME bios image:
                    • Sebastian Codrean
                      BIOS file for ASUS F542UN laptop
                      by Sebastian Codrean
                      Hello to all of you! I need help with a BIOS file.
                      The BIOS chip is fried on my Asus F542UN laptop, and I bought a new chip that needs programming. I have a CH341a programmer but I need a .bin BIOS file. On Asus support page the firmware has another extension, .310 and from reading on this forum I understand that that file is not complete BIOS.
                      So, in short I need the "complete" BIOS .bin file to flash on the new chip. Another issue is that on back of the case the label says F542UN but on the sticker on the motherboard it's X542UN.
                      02-20-2025, 10:25 AM
                    • caglarec2268
                      Asus X515EA Bios File Please
                      by caglarec2268
                      merhaba dizüstü bilgisayarım windows ile bios update yaparken kapandı.
                      Now "please follow the steps below to recover your bios" text remains on the screen
                      I tried backup bios files from the site but the keyboard did not work properly or the ssd did not read the disk. Can my bios be repaired? Or is there a correct active bios? please help thank you.
                      laptop model x515ea-bq945w
                      s/n: R4N0CV02K527148
                      CN:HWFB
                      Board model; ASUS X415EA R7.0
                      bios chip: GD25Q128...
                      11-27-2024, 03:51 AM
                    • Citymin
                      by Citymin
                      S/N : 5RNK9FFT70...
                      08-05-2025, 05:12 AM
                    • maanee11
                      Looking for BIOS flash file for HUAWEI MateBook X Pro 2019 (MACH-WX9)
                      by maanee11
                      Hello Everyone,
                      I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
                      It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
                      In the website, you can only see specs etc.
                      I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...
                      Today, 04:08 AM
                    • wakethesleep1111
                      Bios File Needed for asus tuf15
                      by wakethesleep1111
                      Hi im new and I have a question. I am in need of a bios file to flash my bios with preferably without the bios password included. I have a Tuf f15 gaming laptop. The model is a TUF506L. The bios chip is a Winbond W25Q128JV. The size is 16777216.
                      05-27-2025, 10:56 PM
