Hp 15 dau88mm6a0 bios
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    I need bios hp 15 (dau88mm6a0). Help me thanx.
  • imranromi
    • Jan 2015
    • 1288
    • Pakistan
    Re: Hp 15
    Any one help me need bios.
    • kazia
      • May 2015
      • 145
      • indonesia
      Re: Hp 15
      post detail... and old dump
      • imranromi
        • Jan 2015
        • 1288
        • Pakistan
        Re: Hp 15
        the problem is capslock blinks 2 time no dispaly the bios chip is winbond 25q64fw but my programmer cannot support this chip and i cannot bkup old dump.
        • kazia
          • May 2015
          • 145
          • indonesia
          Re: Hp 15
          then you need 1.8v adapter/programmer for that chip,
          • imranromi
            • Jan 2015
            • 1288
            • Pakistan
            Re: Hp 15
            there is no list is programmer winbond 25q64fw an other chip winbond 25q64bv/fv also support before read chip first select device the device list winbond 25q64fw no number is chip.but my problem is not chip i need bios and bios dump another chip 25q64bv/fv i think is working another chip 64byts.
            • kazia
              • May 2015
              • 145
              • indonesia
              Re: Hp 15
              it's different voltage fw and bv, measure pin8 1.8v or 3,3v
              • smali
                • Sep 2014
                • 287
                • Pakistan
                Re: Hp 15
                post your complete model number and product number.
                • imranromi
                  • Jan 2015
                  • 1288
                  • Pakistan
                  Re: Hp 15
                  SERIAL NUMBER:5CD4401JYJ
                  MODEL:15-F059WM
                  PRODUCT:J8X13UA#ABA
                  MOBOau88mm6a0
                  • smali
                    • Sep 2014
                    • 287
                    • Pakistan
                    Re: Hp 15
                    There are five type of file for your model on Hp officially site first read your old dump and match the ID as mentioned in the End of list or try all five one is definitely will match.
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      Re: Hp 15
                      Agree with kazia, could be corrupt when you reprogrammed with programmer which not supported for IC low voltage windbond FW series. or you can kill the IC its self with 3.3v
                      what's your programmer?
                      AFAIK, only sofi-sp16b that has supported 1.8v, if not sofi then you need adapter to convert 3.3v to 1.8v
                      • imranromi
                        • Jan 2015
                        • 1288
                        • Pakistan
                        Re: Hp 15
                        chip problem is solved i replace the ic 25q64cv is working but i need bios dump.
                        • imranromi
                          • Jan 2015
                          • 1288
                          • Pakistan
                          Re: Hp 15
                          smali its not working bios all dump check
                          • smali
                            • Sep 2014
                            • 287
                            • Pakistan
                            Re: Hp 15
                            Then you have not bios problem because all the above BIN files are according to your provided model.
                            • imranromi
                              • Jan 2015
                              • 1288
                              • Pakistan
                              Re: Hp 15
                              caps lock 2 times blink and no display 2 times blink i think bios problem.
                              • smali
                                • Sep 2014
                                • 287
                                • Pakistan
                                Re: Hp 15
                                what is the battery charging status?
                                • kazia
                                  • May 2015
                                  • 145
                                  • indonesia
                                  Re: Hp 15
                                  I think this is the main problem, you cannot replace 1.8v chip with 3.3v chip.
                                  • imranromi
                                    • Jan 2015
                                    • 1288
                                    • Pakistan
                                    Re: Hp 15
                                    laptop charge battery.
                                    • meritosari
                                      • Oct 2010
                                      • 774
                                      • Indonesia
                                      Re: Hp 15
                                      watch this:
                                      https://www.youtube.com/watch?v=Mg-baWnBOIg
                                      • imranromi
                                        • Jan 2015
                                        • 1288
                                        • Pakistan
                                        Re: Hp 15
                                        bios chip problem is solved update the programmer software before the software update there is no list winbond 25q64fw after update software there is list winbond 25q64fw but the chip problem is solved.
                                        • Habble7
                                          by Habble7
                                          Suspected Cause:
                                          Troubleshooting Attempts:
                                          05-22-2025, 07:28 AM
                                        • haitham sharabati
                                          [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
                                          by haitham sharabati
                                          Hello engineers 😀,
                                          I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
                                          🔧 Device Info:
                                          - Model: HP 15-da2007ne
                                          - Product Number: 8XF55EA#ABV
                                          - Serial Number: CND0338P0D
                                          - CPU: Intel Celeron N4000
                                          - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
                                          💀 Problem:😅
                                          - Device shows “Administrator Password”...
                                          Today, 04:54 AM
                                        • Citymin
                                          by Citymin
                                          S/N : 5RNK9FFT70...
                                          08-05-2025, 05:12 AM
                                        • DynaxSC
                                          by DynaxSC
                                          11-17-2023, 10:56 AM
                                        • MDSI
                                          HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
                                          by MDSI
                                          I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
                                          Details:
                                          Model : HP OMEN 17-an012nf
                                          Motherboard Part Number : DAG3BAMBAF0 REV : F
                                          Serial Number (S/N) : 5CD7280D51
                                          BIOS chip : Winbond W25Q64VSIQ
                                          Programmer : EZP2023+
                                          Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
                                          I already...
                                          07-28-2025, 07:11 AM
