Asus R500V Black Screen (K55VD) bios
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Hello My friends
    I have here a Asus R500V with a Black Screen, mobo boots, but no keyboard, mouse or picture are detected.
    Motherboard : K55VD REV. 3.1
    Anyone with a bios dump to share ?
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus R500V Black Screen (K55VD)
    read and post old bios i will fix it
    Im Back... sort of...
    • passete
      Living=Sharing
      • Jun 2015
      • 487
      • France
      Thanks my good friend, i apreciate your will to help.
      I found a dump on the web, flashed and it's working.
      But again, i've lost the Win8 key, can you retreive my key on my corrupted dump ?
      I post here the working dump found on the web.
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        you may try this
        • passete
          Living=Sharing
          • Jun 2015
          • 487
          • France
          you may try this
          I think that you didn't understand what i wrote, lol we are not English, both of us !
          The dump posted, it's not mine, but the one i found on the net.
          The laptop is now working, but i don't have anymore the Windows 8 key.
          My question was : can you retreive my Win8 key from my corrupted bios ?
          • Technodoc
            ASUS G614JZ-N3012W Rog Strix need some bios help, laptop black screen
            by Technodoc
            Asus laptop G614JZ-N3012W Rog Strix with i7
            Mainboard G634J-PMV-VGT
            6050A3441302-MB-A01
            2023-02-10
            Power button works okay....power light goes on
            Red "bottom" leds go on
            Charging led works
            Fans do not spin, capslock key does nothing, screen stays black
            I would like to program the bios again, to rule out a corrupted bios.
            However I run into a size error
            The bios chip is a Winbond 25R256JVEN
            Used my Xgecu T-48 to read the bioschip (using select chip as type XM25QH256B @WSON8, read somewhere...
            02-24-2025, 04:46 AM
          • razor_amd
            by razor_amd
            12-15-2020, 07:07 PM
          • grimacelord
            by grimacelord
            07-10-2025, 02:52 PM
          • throwaway327
            by throwaway327
            Model No: RC72LA
            Serial No: SBNVKD001014459
            06-18-2025, 05:52 PM
          • mitchw
            HP 14s-fq1010nm Black screen after BIOS update - cannot downgrade
            by mitchw
            Just had a customer bring in a HP 14s-fq1010nm to do some maintenance.
            After updating the BIOS to the latest (F.35) I get black screen (no backlight turning on). However the backlight turns on if I connect an external display to HDMI, but when booting to Windows, both displays remain black.
            After disconnecting internal LCD, and plugging in external display via HDMI, it works on external.
            I tried downgrading it using official method - using an USB drive with older BIOS version, but it fails, saying that the BIOS files are corrupted. I used about 5 different older BIOS versions...
            04-29-2025, 03:45 PM
