HP Elitebook 820 G2 bios needed
Re: HP Elitebook 820 G2 bios needed
you send me a bios is not good this board main bios 16mb you send me 2 mb plz upload 16mb.Comment
Hi I kindly ask for instructions how-to extract BIOS form my laptop. it is an HP elitebook 820 g3 and bios is locked. I got an smc.bin file from Hp but it did not owrk so I would like extract the bios and see what to do.
I will eventually replace the chip
Thank youComment
Ok real easy take your top half of your original file and merge it with the bottom half of either the update or donor file so let's say your bio's file is 8mb so the first 4mb merge to the other 4mb and you are done on most hp on newer ones pass words are stored in the kbc all doable just need the correct programmer to load the clean firmware and the last is the newer hex tool using disable code .
Techman1025Comment
Thanks for your kind reply I was not completely clear. The laptop I am trying ti fix is BIOS locked. I am not a tech but I have good skills...the problem is I do not know how to read the BIOS from the device.Ok real easy take your top half of your original file and merge it with the bottom half of either the update or donor file so let's say your bio's file is 8mb so the first 4mb merge to the other 4mb and you are done on most hp on newer ones pass words are stored in the kbc all doable just need the correct programmer to load the clean firmware and the last is the newer hex tool using disable code .
Techman1025
So I was wondering if it exists any sofwtare capable doing this.
I believe the hardware solution is to physically connect to the chip and read the BIOS. I am ready to do it as well.Comment
.You excuse ops I translate
please tell me if it is at least this the integrated 25L12873F bios on my hp elitebook 820 g2. Thank youComment
no this bios is corrupt how to read and save can you save eprom programmer if use universal bkup tools software is not good use programmer and save file.Comment
@saveriuccio
sono italiano e ti rispondo io poi traduco in inglese. Per il dump devi fisicamente collegarti al chip con un programmatore BIOS e leggerlo. Non c'è altro modo.
To get the proper dump you have to physically connect connect to the chip and read it with a EEPROM programmer. This is the only way toget a valid dump.Comment
by DynaxSCHi, I have an MSI PRO B660M-G DDR4 board with damaged BIOS and i need a bios dump from a real board, along with MAC, UUID and Serial Number info (eg. a BIOS screenshot and pictures from the board stickers).
I need to reconstruct the bios on my board, based on another bios image form a real board - meaning a bios image containing MAC address, UUID and Serial number. A stock BIOS is not suffiecient, as it is impossible to discover where the MAC, UUID and SerialNumber are stored. Tried with a similar board, but there are too much differences, and the stock BIOS is missing a lot of...11-17-2023, 10:56 AM -
I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...-
Channel: BIOS Requests ONLY!
by vinaypundithI have this laptop that does boot but it's on an older BIOS that has issues with Secure Boot, and I cannot use the normal Razer BIOS updater because for some reason the serial number is missing / got deleted somehow (Common issue on this model, from what I've read). I got a dump of the BIOS chip (or at least what I think is the BIOS chip), and its 16MB in size - the files from the Razer BIOS update are 8MB. (There's two 8MB files, am I supposed to combine these somehow? Or combine with an Intel ME firmware? I have no idea).
So, I'm looking for a BIOS dump for this machine - a 16MB one....-
I badly need bios dump for HP DM1-4000er,
Model: HP DM1-4000er
Motherboard: DA0NM9MB6D0 REV.D
Product: QJ490EA#ACB
Please help. My bios chip burned so I don't have the old bios anymore. I need bios dump before I can install the replacement.-
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
- Loading...
