ASUS k56CB bios dump core i7 need.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Thank you very much to all.
  • Pragmatiko
    • Jul 2013
    • 468
    • IT
    Re: ASUS k56CB bios dump core i7 need.
    Every time i need help, never give reply. However solved, thank you to all.
    • polytek
      • Dec 2013
      • 496
      • TUNISIA
      backup your old bios and try this:
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Thank you polytek
        • firas_moumou
          • Sep 2010
          • 8
          Thank you very much
          • fsc2003
            • Mar 2015
            • 30
            • turkey
            thanks very much
            • hondaxr
              • Jun 2014
              • 21
              • portugal
              Thanks..
              • canali
                • Oct 2014
                • 192
                • turkey
                Thanks..
                • scream7634
                  • turkey
                  ASUS k56CB bios dump core i7 need me to. gpu 740m. can you help me?
                  • peste
                    • 12811
                    • ROMANIA
                    try..
                    • razor_amd
                      by razor_amd
                      12-15-2020, 07:07 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • Habble7
                      by Habble7
                      Suspected Cause:
                      Troubleshooting Attempts:
                      05-22-2025, 07:28 AM
                    • Anchar777
                      ASUS P1412CE need BIOS DUMP
                      by Anchar777
                      Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
                      06-26-2025, 03:39 AM
