HP 15-p251nv DAY23AMB6F0 (Quanta Y23A) BIOS
  • toni31
    • Jun 2012
    • 44
    • Thessaloniki
    The laptop came to me after a good bath of coffee.
    I make a good cleaning with isopropyl and flux off spray and then inspection with no sign of damage. Power on MB with 0,77A consumption. Fan is spinning, CPU, GPU warmed up but i can't say the same for FCH and nothing on screen.
    I make some measurements.
    Voltage is Before PWRBTN/After PWRBTN
    PL11: 167k 3V/3V
    PL12: 173K 0V/0,959V
    PL17: 12,3Ω 0V/0,995V
    PL14: 64,6Ω 0V/1.371V
    PL16: 9.7Ω 0V/1.098V
    PL18:9.7Ω 0V/1.098V
    PL21:27.3Ω 0V/1V
    PL22: 69.6Ω 0V/1.199V
    PL26:0.486K 0V/1.396V
    PL24: 203.3Ω 0V/1.136V
    PL25: 9K 0V/5V
    PL29: 16.6K 0V/3.377V
    I can't find the schematic but i think i have all the voltages.
    Any help?
  • nazrul145
    • Jan 2014
    • 339
    • BD
    Re: HP 15-p251nv DAY23AMB6F0 (Quanta Y23A)
    try to flash bios.
    • toni31
      • Jun 2012
      • 44
      • Thessaloniki
      I'm looking around for bios file but no luck
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Here
        • toni31
          • Jun 2012
          • 44
          • Thessaloniki
          Thanks for the file but nothing changed.
          Any other solution?
          • dj_ricoh
            • 2073
            • uk
            What kbc you got?
            • toni31
              • Jun 2012
              • 44
              • Thessaloniki
              Kb9028q c
              • toni31
                • Jun 2012
                • 44
                • Thessaloniki
                Here another bios:
                HP 15-p030nr
                DAY23AMB6F0 REV.F (Quanta Y23A)
                BID022C3 F.29
                The bios not resolve my problem i try to find datasheet for KB9028Q_C
                • toni31
                  • Jun 2012
                  • 44
                  • Thessaloniki
                  Can anyone tell me if the KB 9028 is programmable
                  • mehar
                    • Feb 2015
                    • 12
                    if you ask me i think it is programmable because kb901X is programmable and has a size of 128kb and it is the series of kb902X and i think this one will be size of 256kb its just my assumption but your laptop is ON than i think it is not kbc problem so first go for reflowing the FCH
                    wish you all the best.
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      after decrypted file from official hp web site, there are 3 files, i don't know what you need.
                      2x 4.096kb and 1x8.192kb
                      make sure your programmer already supporting for new bios chip that has low voltage 1.8v (my opinion)
                      • toni31
                        • Jun 2012
                        • 44
                        • Thessaloniki
                        but i think it's 3.3V
                        Take a look here
                        http://www.elnec.com/en/device/GigaD...5BSOP8-200%5D/
                        • crocush20
                          • Feb 2016
                          • 17
                          • qweqweq
                          Thankyou
                          • adeellaptop
                            • May 2016
                            • pakistan
                            Originally posted by pragmatiko
                            here
                            thanx its working for me.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1490
                              • portugal
                              tony 3.3 and 5 volts will be present on S3 only , meaning that 3.3 and 5 volts will appear on the coils after machine start . chek main vcc lines for KBC as also chek voltage present on powerbutton and bios . i got a machine that wont start up , it does charge , it turn on and off like 1 milisecond (once i press on off ) cheking local stuff no shorts found , thinking in possiblew SIO problem , but without pdf do make extra tests it becomes a bit try it or fuck it .
                              indeed all KB901X series are programable , major is 128k , but allready had some with 64kb or 256kb , in case you need EC files let me know , also for programing you need to use keyboard socket to wire to your programmer in order to programme SIO
                              • 100nick
                                • Sep 2014
                                • 16
                                • Portugal
                                ec dump, donwload from external site...for test
                                regards
                                • carlosparada
                                  • Jun 2016
                                  • Bolivia
                                  hi friends... I have the same problem, with same values of PL... can you help me?? Please?
                                  • slavden82
                                    • Jan 2017
                                    • Russian
                                    Originally posted by toni31
                                    Here another bios:
                                    HP 15-p030nr
                                    BID022C3 F.29
                                    with this dump the laptop started up, thanks.
                                    • ravenmx
                                      • May 2018
                                      • 182
                                      • puebla
                                      try this working 100 %
                                      • fharlock999
                                        • Nov 2017
                                        • 62
                                        • Chile
                                        Re: HP 15-p251nv DAY23AMB6F0 (Quanta Y23A) BIOS
                                        thanks you!
