HP 15-p251nv DAY23AMB6F0 (Quanta Y23A) BIOS
  • toni31
    • 44
    • Thessaloniki
    The laptop came to me after a good bath of coffee.
    I make a good cleaning with isopropyl and flux off spray and then inspection with no sign of damage. Power on MB with 0,77A consumption. Fan is spinning, CPU, GPU warmed up but i can't say the same for FCH and nothing on screen.
    I make some measurements.
    Voltage is Before PWRBTN/After PWRBTN
    PL11: 167k 3V/3V
    PL12: 173K 0V/0,959V
    PL17: 12,3Ω 0V/0,995V
    PL14: 64,6Ω 0V/1.371V
    PL16: 9.7Ω 0V/1.098V
    PL18:9.7Ω 0V/1.098V
    PL21:27.3Ω 0V/1V
    PL22: 69.6Ω 0V/1.199V
    PL26:0.486K 0V/1.396V
    PL24: 203.3Ω 0V/1.136V
    PL25: 9K 0V/5V
    PL29: 16.6K 0V/3.377V
    I can't find the schematic but i think i have all the voltages.
    Any help?
  • nazrul145
    • Jan 2014
    • 333
    • BD
    Re: HP 15-p251nv DAY23AMB6F0 (Quanta Y23A)
    try to flash bios.
    • toni31
      • 44
      • Thessaloniki
      I'm looking around for bios file but no luck
      • Pragmatiko
        • Jul 2013
        • 468
        • IT
        Here
        • toni31
          • 44
          • Thessaloniki
          Thanks for the file but nothing changed.
          Any other solution?
          • dj_ricoh
            • 2073
            What kbc you got?
            • toni31
              • 44
              • Thessaloniki
              Kb9028q c
              • toni31
                • 44
                • Thessaloniki
                Here another bios:
                HP 15-p030nr
                DAY23AMB6F0 REV.F (Quanta Y23A)
                BID022C3 F.29
                The bios not resolve my problem i try to find datasheet for KB9028Q_C
                • toni31
                  • 44
                  • Thessaloniki
                  Can anyone tell me if the KB 9028 is programmable
                  • mehar
                    • Feb 2015
                    • 12
                    if you ask me i think it is programmable because kb901X is programmable and has a size of 128kb and it is the series of kb902X and i think this one will be size of 256kb its just my assumption but your laptop is ON than i think it is not kbc problem so first go for reflowing the FCH
                    wish you all the best.
                    • meritosari
                      • Oct 2010
                      • 774
                      • Indonesia
                      after decrypted file from official hp web site, there are 3 files, i don't know what you need.
                      2x 4.096kb and 1x8.192kb
                      make sure your programmer already supporting for new bios chip that has low voltage 1.8v (my opinion)
                      • toni31
                        • 44
                        • Thessaloniki
                        but i think it's 3.3V
                        Take a look here
                        http://www.elnec.com/en/device/GigaD...5BSOP8-200%5D/
                        • crocush20
                          • Feb 2016
                          • 17
                          • qweqweq
                          Thankyou
                          • adeellaptop
                            • May 2016
                            • 3
                            • pakistan
                            Originally posted by pragmatiko
                            here
                            thanx its working for me.
                            • highpulse
                              i hate HP
                              • May 2013
                              • 1488
                              • portugal
                              tony 3.3 and 5 volts will be present on S3 only , meaning that 3.3 and 5 volts will appear on the coils after machine start . chek main vcc lines for KBC as also chek voltage present on powerbutton and bios . i got a machine that wont start up , it does charge , it turn on and off like 1 milisecond (once i press on off ) cheking local stuff no shorts found , thinking in possiblew SIO problem , but without pdf do make extra tests it becomes a bit try it or fuck it .
                              indeed all KB901X series are programable , major is 128k , but allready had some with 64kb or 256kb , in case you need EC files let me know , also for programing you need to use keyboard socket to wire to your programmer in order to programme SIO
                              • 100nick
                                • Sep 2014
                                • 16
                                • Portugal
                                ec dump, donwload from external site...for test
                                regards
                                • carlosparada
                                  • Jun 2016
                                  • 3
                                  • Bolivia
                                  hi friends... I have the same problem, with same values of PL... can you help me?? Please?
                                  • slavden82
                                    • Jan 2017
                                    • Russian
                                    Originally posted by toni31
                                    Here another bios:
                                    HP 15-p030nr
                                    BID022C3 F.29
                                    with this dump the laptop started up, thanks.
                                    • ravenmx
                                      • May 2018
                                      • 165
                                      • puebla
                                      try this working 100 %
                                      • fharlock999
                                        • Nov 2017
                                        • 61
                                        • Chile
                                        Re: HP 15-p251nv DAY23AMB6F0 (Quanta Y23A) BIOS
                                        thanks you!
                                        • lpraderi
                                          Need help with HP15-fxxxxx Quanta U99/U92 LVDS <> eDP conversion.
                                          by lpraderi
                                          Hello , for some time I was studying Quanta U9x/8x schematics and the option to use both type of screen (LVDS 40 pin / eDP 30 pin).
                                          In some cases to use LVDS screen PCB use converter IC RTD2132/6
                                          Now I found an HP 15 F series U99 mainboard with RTD chip not populated and LVDS 40 pin lcd touch screen
                                          at the same time I have another HP 15 N series with Quanta U92 mainboard and RTD2136 with eDP 30 pin lcd screen (no touch).
                                          Maybe someone more experienced in the subject can clarify if is posible to change type of screen used with some resistors / bios options change.
                                          11-25-2023, 09:31 AM
                                        • Francisco.s
                                          Quanta N76 power-on issue.
                                          by Francisco.s
                                          Hello, I'm trying to repair an HP 27 Quanta N76 (DA0N76MB6E0 Rev E).
                                          I only get 3.3V, 5V, and 1.05V; no other voltages.
                                          I tried the BIOS and changed the KBC. The KBC self-programmed upon power-up after changing it.
                                          The VR-On is missing for NCP81220, but 1.2V is also missing for DDR4, so 1P2V_PWRGD is low. SUSON or DDR_VTT_EN are not present on the DDR4 voltage regulator (RT8231BGQW). It seems the KBC isn't triggering these signals.
                                          I'm using the Quanta N91 schematic, but there are too many changes that make it nearly impossible to measure signal...
                                          07-14-2025, 02:20 PM
                                        • pleomax1110
                                          Quanta DA0R05MB8D2 Rev. D (Quanta R05 / Dell 14z-N411z) schematics needed
                                          by pleomax1110
                                          Hello, everyone!
                                          I need schematics of this board:
                                          Model: Dell Inspiron 14z-N411z
                                          Board No: DA0R05MB8D2
                                          REV: D
                                          Quanta project: R05
                                          I have already seen the file ''quanta R02_UMA.pdf'' in this thread:
                                          https://www.badcaps.net/forum/showth...dell+14z-n411z
                                          but it is differ from R05_UMA and it can't help me in my case.
                                          The main problem of the laptop is as follows:
                                          LED backlight is absent in the screen and appropriate 36's contact of the LVDS 40pin 1ch connector is shorted...
                                          10-21-2022, 01:56 PM
                                        • ShortCircuited
                                          Quanta Y23A
                                          by ShortCircuited
                                          Looking for the openboard files if anyone has them. I did find the .pdf. Thanks in advance for any help.
                                          03-02-2020, 01:34 PM
                                        • ferah831208
                                          HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
                                          by ferah831208
                                          I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
                                          12-07-2024, 04:02 PM
