Samsung np275 bios
  • quic307
    • Jun 2015
    • 255
    • Greece
    Samsung np275 bios
    I need bios for NP275e (lampard 14/15a), its 4mb.
    Its with amd E2 and the issue is no signal.
  • quic307
    • Jun 2015
    • 255
    • Greece
    Re: Samsung np275 bios
    Thank you, I found it .... but same issue, I'll try reballing.
    • rookieme
      • Oct 2014
      • 397
      • Greece
      thank you!!!
      • canali
        • Oct 2014
        • 192
        • turkey
        thank you!!!
        • purwanto axtp
          • May 2024
          • 16
          • Indonesia
          thanks.. is good..
          working..
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
          • Vesko356
            by Vesko356
            08-11-2023, 03:27 AM
            09-07-2024, 05:50 AM
          • TJ65
            Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
            by TJ65
            i made out of two broken Samsung Galaxy Tabpro S one that works partially.
            The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
            I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
            The problem is, that the micom Version doesn't match with the bios version, see picture.
            How can i update the Micom Version? The Samsung bios update wont work.
            With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
            01-09-2025, 01:35 PM
