Samsung np275 bios
  • quic307
    • Jun 2015
    • 255
    • Greece
    Samsung np275 bios
    I need bios for NP275e (lampard 14/15a), its 4mb.
    Its with amd E2 and the issue is no signal.
  • quic307
    • Jun 2015
    • 255
    • Greece
    Re: Samsung np275 bios
    Thank you, I found it .... but same issue, I'll try reballing.
    • rookieme
      • Oct 2014
      • 398
      • Greece
      thank you!!!
      • canali
        • Oct 2014
        • 192
        • turkey
        thank you!!!
        • purwanto axtp
          • May 2024
          • 16
          • Indonesia
          thanks.. is good..
          working..
          • Kjell
            Samsung Series 9 - BIOS issue
            by Kjell
            After installing Linux, I can no longer enter the BIOS of my Samsung Series 9 (NP900X3C) laptop. When pressing [F2] during boot I simply get a black screen. Same thing when pressing [F10] and choosing "Setup" from the "App Menu" tab. Apparently this is a relatively common issue with Samsung laptops of that generation, but unfortunately i haven't been able to resolve the issue (yet).
            Things i've tried so far; reinstalled Windows 10, checked for redundant boot entries, tried to factory reset using the emergency keyhole, attempted to clear the NVRAM by physically...
            08-01-2025, 09:15 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • wizard13
            Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
            by wizard13
            I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
            I have checked the forum and the available documentation but could not find a solution specific to my issue.
            • Brand & Model: Dynabook Satellite Pro C50D-B-100
            • Part Number (P/N): PYU13E-00C00PFR
            • Serial Number (S/N): 22028896H
            • System Configuration (SC): A1PYU13E1127
            • Motherboard Model: IP3_ACN16_MB_V21_20211222A
            • Power Input: DC 19V –
            02-28-2025, 02:43 AM
            by Vesko356
            08-11-2023, 03:27 AM
            09-07-2024, 05:50 AM
