Can anybody has a bios dump of Asus X452CP? The problem with the laptop is there"s a light on the screen but no pictures, i tried to external VGA but also has no display, so i will try to reprogram the bios. Thanks in advance.
Re: Can anybody has a bios dump of Asus X452CP?
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
Actually the windows is booting because it has a welcome sound, i think the laptop is working now but no display output in any port....i will try your suggestion sir then i will back to you, thanks for your input it helps a lot.Comment
i think your video its gone.
i got a asus g50v with 9800m in it and i got a problem on the mxm socket.
tough the video card works but as soon i plug in the card the notebook shuts down in 3 sec.
IF i take the video out the it works normal ( i here windows sound) , HDD working but no display. ofc no video card in notebook.Just cook it! It's already broken.Comment
probably sir because i tried to reflow the GPU but still no display....i think the GPU is the main reason on corrupted bios..and this type of laptop has a common issue on GPU's...i think your video its gone.
IF i take the video out the it works normal ( i here windows sound) , HDD working but no display. ofc no video card in notebook.Comment
I have same problem with you recently, happen when i change several BIOS option and save it, after reboot no display at all, using above bios dump result same simptoms like above, windows successfull loading but no display.
Finally i've found this bios dump and flashed it, and it WORKED..
try this..
this X450VP rev 2.1 Main board have several version with the same MB name,
one with intel hd graphics only, one with nVidia GT720M graphics, and one with AMD 8530M Graphics, My MB is the AMD one..
maybe it's to late, but maybe others with the same problem will find this usefull, best regards..
by mkdjDear all,
I would appreciate if someone could take time to explain the issue, so that I can learn. But I would...-
Channel: BIOS Requests ONLY!
by razor_amdWith ASUS, not everything is quite so simple. I will show you my way. It may be longer or harder but it is the right way to do it in my humble opinion.
This is the picture of 3 similar ASUS motherboards, all of them being X555LD...-
by piratiHello everyone,
by DynaxSCHi,
Usually on ASUS boards it worked...-
by AhariHi all,
I...-
- Loading...
