Need Asus UX31A bios dump
  • zonzolo
    • Apr 2015
    • 13
    • italy
    Hello i need a dump bios of asus model UX31A (uefi bios)with main board code Ux31a2 rev. 2.0
    thanks in advance
  • zonzolo
    • Apr 2015
    • 13
    • italy
    Re: Need Asus UX31A bios dump
    Please
    no one has this dump??
    • alihomee
      • Dec 2012
      • 1599
      • malaysia
      try this
      • zonzolo
        • Apr 2015
        • 13
        • italy
        Thanks a lot.
        • Claudio Silva
          • Feb 2013
          • 94
          • Portugal
          Originally posted by zonzolo
          Thanks a lot.
          Bios worked?
          • lxlx4430
            • Sep 2012
            • 18
            • india
            thx
            • azacelo
              • Mar 2017
              • Israel
              Thank you Alihome
              • dolunay79
                • Oct 2016
                • 18
                • turkey
                thanks
                • cihan
                  • Mar 2015
                  • istanbul
                  ux31a bıos dump plase 8mb ??????
                  • pimpstar
                    • Nov 2014
                    • Barcelona
                    thank this work
                    • Magnusa2
                      • Jul 2017
                      • 66
                      • India
                      does anyone have board view, please
                      it's urgent
                      • mohamed salah
                        • May 2017
                        • 3
                        • egypt
                        ok
                        • apppostol
                          • Nov 2020
                          • 4
                          • Russia
                          Originally posted by mohamed salah
                          ok
                          Worked! Thanks!
                          • nsilvan
                            • Mar 2019
                            • 30
                            • baja california
                            thanks work for me
                            • nsilvan
                              • Mar 2019
                              • 30
                              • baja california
                              ok
                              work for me
                              • yukselen
                                yukselen
                                • Jun 2021
                                • 43
                                • türkiye
                                Originally posted by alihomee
                                try this
                                thank you it works
                                • mkdj
                                  by mkdj
                                  Dear all,
                                  10-19-2025, 04:41 AM
                                • razor_amd
                                  by razor_amd
                                  12-15-2020, 07:07 PM
                                • pirati
                                  by pirati
                                  10-27-2025, 04:20 PM
                                • DynaxSC
                                  by DynaxSC
                                  06-14-2024, 03:49 PM
                                • Ahari
                                  by Ahari
                                  I...
                                  08-13-2025, 06:12 AM
