asus A46C bios dump
  • salawayon
    • Nov 2012
    • 568
    • philippines
    asus A46C bios dump
    MB: K46CM REV. 2.0
    This is a dead unit. With no 3v/5v and no voltage at power switch. Bios file at asus support is only 6mb and my backup is 8mb...
    Thanks...
  • salawayon
    • Nov 2012
    • 568
    • philippines
    Re: asus A46C bios dump
    Or a schematics for the said unit..
    Thanks...
    • yozas
      • Feb 2014
      • lithuania
      Thanks...
      here you go: http://s000.tinyupload.com/index.php...55444841438960
      • salawayon
        • Nov 2012
        • 568
        • philippines
        This unit was repaired after i found out that the BQ25A charging ic was the main cause of the problem. BTW, even the bios file from asus support site is only 6mb i still tried to use it but still no changes. Then write back my own backup while waiting for someone could share the needed bios file dump.... i repaired this unit after playing with the bios even it wasn't the problem...
        Thanks...
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • Habble7
          by Habble7
          Suspected Cause:
          Troubleshooting Attempts:
          05-22-2025, 07:28 AM
        • Anchar777
          ASUS P1412CE need BIOS DUMP
          by Anchar777
          Sorry for creating a second post, I didn't understand how to fix the error in the message. I need help, laptop ASUS P1412CE (P1411CEA-EK0395X) SN: N4NXCV033901146. There was a failure during BIOS flashing, and the laptop stopped turning on. The original, non-working BIOS is attached. Unfortunately, I was unable to correctly generate the BIOS from what is presented on the Asus website. Help me make a dump. Thank you....
          06-26-2025, 03:39 AM
