asus A46C bios dump
  • salawayon
    • Nov 2012
    • 578
    • philippines
    asus A46C bios dump
    MB: K46CM REV. 2.0
    This is a dead unit. With no 3v/5v and no voltage at power switch. Bios file at asus support is only 6mb and my backup is 8mb...
    Thanks...
  • salawayon
    • Nov 2012
    • 578
    • philippines
    Re: asus A46C bios dump
    Or a schematics for the said unit..
    Thanks...
    • yozas
      • Feb 2014
      • lithuania
      Thanks...
      here you go: http://s000.tinyupload.com/index.php...55444841438960
      • salawayon
        • Nov 2012
        • 578
        • philippines
        This unit was repaired after i found out that the BQ25A charging ic was the main cause of the problem. BTW, even the bios file from asus support site is only 6mb i still tried to use it but still no changes. Then write back my own backup while waiting for someone could share the needed bios file dump.... i repaired this unit after playing with the bios even it wasn't the problem...
        Thanks...
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • Ahari
          by Ahari
          I...
          08-13-2025, 06:12 AM
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • ArkzG
          [REQUEST] ASUS TUF A15 FA506NF (2021) - Clean BIOS dump needed (UEFI Password locked)
          by ArkzG
          Hey guys, I have an "ASUS TUF Gaming A15 FA506NF (2021)" that's locked with a UEFI password, I need to reprogram the BIOS chip but can't find a clean ".bin" file for this specific model, I've tried the official BIOS updates from ASUS support page, but they're 32MB updaters that don't extract to a usable 2MB .bin file for direct chip programming.
          What I currently have available:
          - Model: FA506NF (2021)
          - BIOS chip: GD25LQ16 (16Mbit/2MB)
          - Tools: CH341A programmer ready to use
          Does anyone have either a clean 2MB .bin dump of this model,...
          09-26-2025, 09:34 PM
