How to extract fd. from exe. (Bios update)
  • goodguy91
    • Aug 2015
    • 80
    • Finland
    Re: How to extract fd. from exe. (Bios update)
    i have another mx bios chip which i can erase, can use that. still this programmer and software should support this chip, maybe it has some write protection?
    • goodguy91
      • Aug 2015
      • 80
      • Finland
      Re: How to extract fd. from exe. (solved)
      Solved finally
      reflashed bios via programmer and it worked although had loads of mistakes while doing it. bad bios chip, after that too small size bios chip and got errors on boot, it had deleted data which went above chip size 1mb.
      After trying to flash acer travelmate 7520g bios multiple times i ended up checking under heatsink and saw intel cpu T7500, found out it was actually acer extensa 5220 board inside 7520g travelmate case lol. 7520g has amd cpu.
      extensa bios dumps didnt work cause t7500 isnt even supported cpu for that model chipset even with latest bios, so i dloaded modded bios and its working now, had to also change ram memory from 667mhz to 800mhz or it crashed instantly.
      uploaded this working bios file, it has hidden bios options aswell. thx for trying help in thread
      same dump should work on these aswell:
      Extensa 5220
      Extensa 5620
      Extensa 5620G
      Extensa 5620Z
      Extensa 5620ZG
      TravelMate 5320
      TravelMate 5720
      TravelMate 5720G
      • megaraider
        • Jul 2015
        • 307
        • Portugal
        • lupak
          • Sep 2021
          • Italia
          Originally posted by goodguy91
          Solved finally
          Extensa 5220
          Extensa 5620
          Extensa 5620G
          Extensa 5620Z
          Extensa 5620ZG
          TravelMate 5320
          TravelMate 5720
          TravelMate 5720G
          Hallo, I need the bios dump for 5620, is this bin you posted okay? Can I write it?
          • to5it0
            by to5it0
            10-24-2025, 01:35 AM
          • survivalbloke
            Unable to extract Lenovo BIOS file from installer
            by survivalbloke
            I'm working on a Lenovo LOQ 15APH8, Serial# MP2L9MAV. I want to flash a new BIOS onto it, but I'm also trying to learn this process for my own enrichment and professional development.
            I was watching some tutorials, copying the serial info blocks from the old bios to a new bios. Before that though, they use innoextract on the Lenovo .exe. I downloaded Innoextract v1.9 but it tells me my .exe is not a supported inno setup installer(see screenshot). So if I unpack this using 7zip, I do get a .ROM file, but according to my tutorials, I'm looking for a .FD file.
            How can...
            07-16-2025, 03:21 PM
          • iZakre
            HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
            by iZakre
            Hello everybody!
            To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
            The thing is that I had installed TeamViewer and could log into the computer...
            02-19-2023, 02:27 PM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
          • m1ch43lzm
            by m1ch43lzm
            Hi everyone
            09-06-2025, 05:47 PM
