Good day. Guys do you have working bios file for this laptop Toshiba L505-GS5035 Intel version. Totally dead, no lights at all. Tested board and found no heating components. And also all voltage are present, even in power button. I want to test bios first. Bios found on toshiba site is bigger in size. I uploaded bios file from toshiba site. I hope someone can look at it. Thanks very much.
Need bios file Toshiba L505-GS5035
Re: Need bios file Toshiba L505-GS5035
thanks ala_borbe. bios didn't work. I uploaded file from both EC and PCH. While trying to look for the correct bios file, I'll be rechecking the board maybe I missed something. hope somebody got schematics for this one.
@razu
problem is laptop got no lights and does not respond (power) but got alw voltageAttached Filesif you find these attachements useful please consider making a small donation to the site
can you pls try thisAttached Filesif you find these attachements useful please consider making a small donation to the site
Im Back... sort of...
thanks ala_borbe, but I'll hold this file first. I found short on motherboard.I really need schematic since I'm lost on the circuitry.
I'm suspecting a short on this IC but I'm not sure what it is. got markings on top EL=BJ P13. A quick search seems to point on Realtek, but still not clear. Please check my image coz that is how I found short.
1st short found on green markings. I suspected its on the jumper side. then removed solder on jumper which points me to yellow marking. I'm lost there. Hope someone can guide me on here. ThanksAttached Filesif you find these attachements useful please consider making a small donation to the site
That's an RT8015AAttached Filesif you find these attachements useful please consider making a small donation to the site
thanks khaahk. I got a typo on my previous post (Realtek). Anyway, if pins 6 and 7 are shorted to ground. Does it mean ic is faulty? I forgot to remove resistor, Ill be doing it now to know if its the IC is the problem.Comment
by to5it0Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
I have opened the laptop and identified the main BIOS chip...2 Photos-
Channel: BIOS Requests ONLY!
by CityminHi all,
S/N : 5RNK9FFT70...-
by maanee11Hello Everyone,
I have HUAWEI MateBook X Pro 2019 (MACH-WX9) whose BIOS got corrupted i beleive. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need BIOS bin/hex file which i could use to reflash it externally via the flasher tool.
It seems like the support page of this model no longer exist: https://consumer.huawei.com/be/lapto...ro-2019/specs/
In the website, you can only see specs etc.
I have not tried to extract the BIOS dump yet as I want to see if there is any ray of sunshine...1 Photo-
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by HOHAHi can you help me
I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
IP3_TN16S_MB_V30_20210901A
This is the old BIOS file, it is corrupted​...-
- Loading...
