Asus K53SD Bios
  • masud
    • Jul 2011
    • 317
    • Bangladesh
    Asus K53SD Bios
    Need Asus K53S Bios, please help.
  • sunilnjarakkat
    • Dec 2013
    • 13
    • u.a.e
    Re: Asus K53SD Bios
    • mk praveen
      • Aug 2014
      • 33
      • india
      Re: Asus K53SD Bios
      hi,
      i need Bios for Asus K53SJ-SX234R laptop with i3core Cpu....
      motherboard partno:- K53SV
      Rev:- 3.00
      regards,
      Praveen
      • alihomee
        • Dec 2012
        • 1575
        • malaysia
        Re: Asus K53SD Bios
        try and post results
        • nsilvan
          • Mar 2019
          • 30
          • baja california
          Re: Asus K53SD Bios
          works alihomee
          • Zeeshanali1
            • Oct 2018
            • 27
            • Pakistan
            Re: Asus K53SD Bios
            100 % ok bios asus K53SD
            zash
            • maybel
              • Dec 2017
              • 24
              • philippines
              Re: Asus K53SD Bios
              thanks men
              • djharold
                • Aug 2015
                • 241
                • COLOMBIA
                Re: Asus K53SD Bios
                thanks
                • razor_amd
                  by razor_amd
                  12-15-2020, 07:07 PM
                • grimacelord
                  by grimacelord
                  07-10-2025, 02:52 PM
                • throwaway327
                  by throwaway327
                  Model No: RC72LA
                  Serial No: SBNVKD001014459
                  06-18-2025, 05:52 PM
                • jbonavita
                  by jbonavita
                  Some issues
                  Things I tried
                  04-29-2025, 09:38 PM
                • lrouw84
                  by lrouw84
                  Hi there,
                  01-28-2023, 01:31 PM
