Hello again. does anybody here have bios file for this laptop. Toshiba L755-S5246. Processor is Intel Pentium B940 2.0ghz. Board code is DA0BLBMB6F0. I want to try bios first. Laptop cannot power on but charging light is lit. Already change nec tokin 2 times but still the same. voltage is present on power button. 5v/3v is also present. No heating components found. And also no short tested. Bios file from website larger than normal. Thanks!
Need toshiba L755 bios file
Re: Need toshiba L755 bios file
i know it sounds stupid but bare with me
on the power button socket you got 3v or after the socket----> foil -------> power button you got 3v?
my friend i got a P755 for nothing because it was the power button problem
(foil bad)
Just cook it! It's already broken. -
The way you describe your problem it doesn't sound like a bios problem.
Try this, and check your pch power lines again.Comment
yup not a bios problem. I just reprogrammed it using known working ones from a tech friend, but still same results. I'll do what you suggested and maybe I found faulty components again. have a nice day. thanksComment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
Programmer models: XGecu TL866II Plus / T48 / T56 / T76
Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
There's also an extra OTP Secu.R...-
by HOHAHi can you help me
I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
IP3_TN16S_MB_V30_20210901A
This is the old BIOS file, it is corrupted​...-
Hello, Could you please help me to find bios files (2mb&4mb) for Toshiba Satellite P55T-A5202? I have already downloaded wrong bios files several times. Every time led behaviours are different....
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
- Loading...
