Hello again. does anybody here have bios file for this laptop. Toshiba L755-S5246. Processor is Intel Pentium B940 2.0ghz. Board code is DA0BLBMB6F0. I want to try bios first. Laptop cannot power on but charging light is lit. Already change nec tokin 2 times but still the same. voltage is present on power button. 5v/3v is also present. No heating components found. And also no short tested. Bios file from website larger than normal. Thanks!
Need toshiba L755 bios file
Re: Need toshiba L755 bios file
i know it sounds stupid but bare with me
on the power button socket you got 3v or after the socket----> foil -------> power button you got 3v?
my friend i got a P755 for nothing because it was the power button problem(foil bad)
Just cook it! It's already broken. -
The way you describe your problem it doesn't sound like a bios problem.
Try this, and check your pch power lines again.Comment
yup not a bios problem. I just reprogrammed it using known working ones from a tech friend, but still same results. I'll do what you suggested and maybe I found faulty components again. have a nice day. thanksComment
by CityminHi all,
S/N : 5RNK9FFT70...-
Channel: BIOS Requests ONLY!
by m1ch43lzmHi everyone
There's also an extra OTP Secu.R...-
by HOHAHi can you help me
I did not find the BIOS file for Toshiba Dynabook Satellite Pro C50-J-10M
IP3_TN16S_MB_V30_20210901A
This is the old BIOS file, it is corrupted​...-
by Forest79Hello,
However, the chip (a Macronix MX25L25673GMI-08G) has a size of 32 MB, and the BIOS file from the Lenovo website (extracted with UEFITool) has a little more than 16 MB. Thus, the software my acquaintance used (SiberiaProg v1.45, with a CH341A Programmer)...-
by maanee11Hello Everyone,
I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...-
- Loading...
