Resetting BIOS passwords on newer laptops
  • BGM
    • May 2015
    • 23
    Welcome to the New Laptop BIOS thread!
    If you have a computer with a missing BIOS password, you may search the internet for solutions. There are lots of solutions for older laptops, but not for the newer ones. So I want to first summarize the old solutions and then query the community for new answers.
    I have the this problem with a Dell Latitude e5520. I buy machines from ebay and rebuild them to distribute to our chapels (it saves a LOT of money). However, I have one with an admin password on the BIOS. There is no way I can complete Dell's change-of-ownership form, so they can't help. There are quite a few people out there in the same position.
    When I say "older laptops" I mean laptops that came out before 2011. It is about that time that they started to change. In particular (since I am trying to solve an issue), Dell laptops with a service tag ending in -1DB3 are amoungst the newer models.
    For these models, the bios passwords are flashed onto an eeprom chip (or there may be several of them, in fact), so it doesn't do any good to remove the RTC battery and all power to clear the CMOS - it doesn't work. Likewise, there is no jumper that you can move around. And removing all the power and leaving the machine sit for a couple days does not work either - I've tried it.
    On this particular machine, the settings in BIOS are not changeable without the password, although it looks like everything is enabled in BIOS, so the computer functions normally and Windows functions normally. I could just send it out like this except that the BIOS is set at version A02 - and I'd really like to update it!
    So the password is supposed to prevent theft and improve security. I've taken the machine down to pieces. Right now it's just a working motherboard that functions, but can't be updated. There's nothing to steal or secure; and I'm not a thief anyway.
    From my research, here are the ways this can be done:
    • Backdoor master password
      This will be hashed from the Dell Service Tag number. There are password generators for older models, but not for the newer ones.
    • Use default password
      Sometimes there is a default master password that a system may accept - it may be worth trying these, but there aren't many options and all the websites out there seem to have the same list, such as this one, and the lists have not been updated probably, for a long time.
    • Get Dell to give you a password.
      Apparently, you are always assumed to have stolen the machine in your possession. Dell will help you only if you can prove you own it. They provide a Change-of-Ownership form, but you have to know the previous legitimate owner.
    • Reset the service tag number
      I can't figure out how to do this, and don't know if it will work.
    • Invalidate the CMOS checksum
      This should reset the password. I can't find a utility that claims to work on a Latitude e5520. One example is the CMOS De-Animator, last updated in 2013, but I have confirmation from the authour that it won't work on the newer machines. However, it is possible that whilst performing this procedure that violate a built-in security measure and cause the BIOS to perfom a complete lockout. But on older machines, this method has been claimed to work well.
    • Flash a new password
      There are some utilities that can do this, but all the ones on the internet are for older laptop models.
    • Short-circuit the eeprom chip
      Apparently, this can be done with a paper clip; but you better make sure you know which chip this is. Problem is that some of the newer computers make use of several chips, and I've read how sometimes those chips may be stored underneath the processor! I haven't tried ths.
    • Use an eeprom flash programmer
      It is a device that can flash codes onto the eeprom chip (I think). To do this you also have to be willing and capable of desoldering the eeprom chip and resoldering them.
    • Finally, pay someone
      There are all kinds of creeps and cracks out there who will take your money and claim that they can give you a password based on your service-tag number. I've never tried this, but they must have a password generator!
    Now, here is a collection of the best pages on the subject of resetting BIOS passwords.
    What I would hope for is for someone to tell me a secure way to do this or point me to a password generator that works. I know that a fellow named Dogbert has figured out how to do this, but he does not release his work for general use.
  • patriciopat
    MerlinMac
    • May 2007
    • 68
    Re: Resetting BIOS passwords on newer laptops
    Hi buddies , I'm also interested in the tricks to eliminate these clavesque sometimes forget . Let's see if we make a database of useful tips like this post together. greetings
    • wallyoz7
      • Mar 2015
      • 21
      E5520 have dual bios chips and they can be replaced.
      Desoldering (hot air rework station) equipment is necessary. Bios chip programmer may used also. The hardest process of a bios chip is the
      time it takes unscrewing a laptop open.
      • patriciopat
        MerlinMac
        • May 2007
        • 68
        A page where you see the way they do? To learn a tip ... a greeting
        • wallyoz7
          • Mar 2015
          • 21
          https://www.youtube.com/watch?v=DFErQh4Hdsw
          I recommend TimsComputerRepair on youtube
          for bios chip replacement.
          • Life Goes On
            • May 2014
            • 264
            • Curacao
            I prefer the solder iron for removing that kind of bios chip, but it's about what s easier for your self, very interesting post bytheway.
            The Night Drop Down, I Will Keep Try Until..., You Never know.
            Dushi Kòrsou, Nos Tei.
            • robocracy
              • Aug 2015
              • singapore
              Thank you so much, the Dogbert method worked very well, just don't forget the Ctrl+Enter
              • goodguy91
                • Aug 2015
                • 80
                • Finland
                I tried basically everything to remove bios password on HP compaq 6720s. It didnt even have Stringent security on. All kinds of bios nuke programs and reseting bios battery with different configurations. It didnt give me any lockdown code if did wrong code more than 5x.
                OS is still working and i can change boot device so wont waste my time on this one anymore. Just a heads up for someone with this laptop and missing bios password... ur gonna need eeprom programmer or new chip mate. Although never tried short circuiting chip.. could work but dont wanna risk it.
                • Lornet
                  • Mar 2021
                  • 27
                  • France
                  Do you know if a Dell master password generator alraidy exist for the system number / Tag with newer suffix as 8FC8 and E7A8.
                  If this is the case, may you share a link ?
                  Thanks for your reply, best regards
                  • SpecialK
                    • Aug 2011
                    • 11
                    I bought a second hand laptop with 8FC8 suffix. I was able to complete the asset transfer process and Dell provided me the master key. So I have an asset tag + the master reset key for that tag. Would this be of any help to anyone, for instance to validate a new version of the keygen?
                    • AAAC
                      • Jan 2020
                      • 458
                      • Mexico
                      @SpecialK
                      It will really help to develop new tools if you can get all the related information (I once did), meaning:
                      (1) - For SYSTEM, the ServiceTag 8FC8 code and its corresponding master password.
                      (2) - For HDD, the Hard-Drive 8FC8 code and its corresponding master password.
                      Then you can go into Setup/BIOS and check the option to "disable the use of master password" or a similar option, save changes along with a system and hard-drive password set, and I believe the suffix 8FC8 will change to 0001, then do the same for the System and Hard-Drive, obtain the corresponding master passwords.
                      Seems like for new 8FC8 suffix Dell engineers have moved that master password calculation into the EmbeddedController/KeyBoardController chip, then also seems like the firmware updates for this chip are encrypted, so it will take a while to obtain the firmware to analyze.
