Asus k555ln bios help
  • soldiers06
    • Jul 2014
    • 21
    • turkey
    hi
    help me
    asus k555ln - motherboard code : x555ld rev.3.1
    bios file
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: Asus k555ln bios help
    read old and post here
    bios for asus needs original file and then fix, otherwise fan at 100%
    Im Back... sort of...
    • soldiers06
      • Jul 2014
      • 21
      • turkey
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3570
        • slovakia
        borbe can u please post details about that fix?
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          sry for unclear English, i was in a hurry
          its not so hard
          you take a dump from bios, nonworking
          download update from Asus web support
          open update file in hex editor (any will do)
          open dumped bios
          by binary search find where main bios start and overwrite with downloaded bios from net
          flash "fixed" dump in eprom and thats it
          maybe there are some tools for that, dono, i do it by hand
          • Life Goes On
            • May 2014
            • 264
            • Curacao
            its not so hard
            open dumped bios
            Thanks for explaining
            The Night Drop Down, I Will Keep Try Until..., You Never know.
            Dushi Kòrsou, Nos Tei.
            • soldiers06
              • Jul 2014
              • 21
              • turkey
              Share robust study the bios me please
              • fredo
                • Aug 2016
                • 72
                • syria
                • dolunay79
                  • Oct 2016
                  • 18
                  • turkey
                  Originally posted by fredo
                  thanks
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Dear Ala Borbe, Can u explain it a bit more for me. How to find main bios by binary search in hex editor?? I use HXD.
                    • throwaway327
                      by throwaway327
                      Model No: RC72LA
                      Serial No: SBNVKD001014459
                      06-18-2025, 05:52 PM
                    • jbonavita
                      by jbonavita
                      Some issues
                      Things I tried
                      04-29-2025, 09:38 PM
                    • lrouw84
                      Asus vivobook s510ua bios changed to x510un
                      by lrouw84
                      Hi there,
                      I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                      I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                      01-28-2023, 01:31 PM
                    • DynaxSC
                      by DynaxSC
                      06-14-2024, 03:49 PM
                    • oragano
                      ASUS ex-b250-V7 motherboard bios corrupted - by me
                      by oragano
                      hey all, i did a silly thing and flashed bios to perfectly working board. None of the asus official download bios would work with ez flash. They all gave error saying not supported bios file. I tried using uefi tool to extract it to a bin file but then ez flash wouldnt even recognise it.
                      So, i used freedos and afudos with the aforementioned bin file i extracted and forced the issue. After bios reprogram, reboot and it was dead. Fans spinning but no post.
                      i have a bios writer and none of the .cap files from the official site work either. I just get one spin, then off, then all fans...
                      10-17-2024, 02:53 AM
