Need Bios dump for HP Probbok 4525s
  • bios
    • Nov 2014
    • 64
    • Philippines
    Hello Guys,
    Can anyone help me, I need bios dump for HP Probook 4525s
    PATEK UMA MB
    09287-1
    48.4GJ02.011
    Thank You..
  • maestro_lpc
    • Mar 2015
    • 14
    • Georgia
    Re: Need Bios dump for HP Probbok 4525s
    Try this
    • bios
      • Nov 2014
      • 64
      • Philippines
      Thank you, I will try it.
      • bios
        • Nov 2014
        • 64
        • Philippines
        Thank you maestro lpc, it works.
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          thank you , it works for me
          • burakmvl
            • Dec 2017
            • 18
            • turkey
            thank you
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • MDSI
              HP OMEN 17-an012nf BIOS dump with EC (DAG3BAMBAF0 REV : F)
              by MDSI
              I'm requesting a full BIOS dump (including EC firmware) for an HP OMEN 17-an012nf laptop.
              Details:
              Model : HP OMEN 17-an012nf
              Motherboard Part Number : DAG3BAMBAF0 REV : F
              Serial Number (S/N) : 5CD7280D51
              BIOS chip : Winbond W25Q64VSIQ
              Programmer : EZP2023+
              Issue : The motherboard is not powering on. Only the 5V rail is present. The 3.3V rail is missing because EN1 on the SY8286B remains stuck at 0V. This signal is driven directly by the EC/SIO. I replaced the 3.3V regulator and confirmed it's working.
              I already...
              07-28-2025, 07:11 AM
            • grimacelord
              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
              by grimacelord
              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
              Motherboard model number: DA0PAMB46A1 REV: A
              Secondary motherboard model number: 0PAB
              SKU: 685K4UA
              Serial number is: 5CD3223BJP
              Recently reflashed this laptop with latest BIOS and once...
              05-07-2024, 08:06 AM
            • DynaxSC
              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
              by DynaxSC
              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
              11-06-2022, 05:22 PM
