Need Bios dump for HP Probbok 4525s
  • bios
    • Nov 2014
    • 64
    • Philippines
    Hello Guys,
    Can anyone help me, I need bios dump for HP Probook 4525s
    PATEK UMA MB
    09287-1
    48.4GJ02.011
    Thank You..
  • maestro_lpc
    • Mar 2015
    • 14
    • Georgia
    Re: Need Bios dump for HP Probbok 4525s
    Try this
    • bios
      • Nov 2014
      • 64
      • Philippines
      Thank you, I will try it.
      • bios
        • Nov 2014
        • 64
        • Philippines
        Thank you maestro lpc, it works.
        • alas3376
          • Nov 2011
          • 382
          • BENIN
          thank you , it works for me
          • burakmvl
            • Dec 2017
            • 18
            • turkey
            thank you
            • Habble7
              by Habble7
              Suspected Cause:
              Troubleshooting Attempts:
              05-22-2025, 07:28 AM
            • DynaxSC
              by DynaxSC
              11-17-2023, 10:56 AM
            • grimacelord
              Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
              by grimacelord
              This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
              Motherboard model number: DA0PAMB46A1 REV: A
              Secondary motherboard model number: 0PAB
              SKU: 685K4UA
              Serial number is: 5CD3223BJP
              Recently reflashed this laptop with latest BIOS and once...
              05-07-2024, 08:06 AM
            • DynaxSC
              Who has a MSI Z590 PRO WIFI - Need BIOS dump ?
              by DynaxSC
              I need a BIOS dump for MSI Z590 PRO WIFI from a real physical board, along with MAC address and serial no.
              It must be a dump from a physical board, as it contains personalized data eg. MAC Address, UUID, Serial no.
              I have a board which has lost the BIOS contents, I have the MAC and serial to this board, and need to insert it into the another BIOS image. To do it, I need to have a real image from a real board, as the images from the MSI site are without this data. The only way to find where MAC/UUID/Serial is located in the BIOS is to have a bios...
              11-06-2022, 05:22 PM
            • TacticalFahrrad
              [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
              by TacticalFahrrad
              I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
              06-30-2025, 04:09 AM
