NEED Gateway LT2210i bios DUmp
  • ry x hunter
    • Jun 2013
    • 184
    • philippines
    hi guys i need help to find bios dump for gateway LT2210i.. please help me.. thanks guys
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: NEED Gateway LT2210i bios DUmp
    pls give motherboard code and your eeprom dump
    Im Back... sort of...
    • ry x hunter
      • Jun 2013
      • 184
      • philippines
      ok sir.. i send it later sir
      • ry x hunter
        • Jun 2013
        • 184
        • philippines
        da0zh9mb6d0 rev d
        • ala_borbe
          aka Donald
          • 1625
          • Malta
          backup old bios and try this
          (same as aspire one 521)
          • Ahari
            by Ahari
            I...
            08-13-2025, 06:12 AM
          • grimacelord
            Trying To Find UUID In BIOS Dump - HP 14-dq0055dx
            by grimacelord
            This laptop is the same laptop I was working on in this thread and I wasn't sure if I should post a new topic or post in that thread because I already solved the issue that thread was discussing and this is a completely different issue although it is dealing with the same laptop. I decided to make a new thread since it's a new issue, but please move if I made a mistake.
            Motherboard model number: DA0PAMB46A1 REV: A
            Secondary motherboard model number: 0PAB
            SKU: 685K4UA
            Serial number is: 5CD3223BJP
            Recently reflashed this laptop with latest BIOS and once...
            05-07-2024, 08:06 AM
          • Habble7
            by Habble7
            Suspected Cause:
            Troubleshooting Attempts:
            05-22-2025, 07:28 AM
          • haitham sharabati
            [Request] Clean BIOS dump for HP 15-da2007ne (8XF55EA#ABV) - N4000 - BIOS Lock
            by haitham sharabati
            Hello engineers 😀,
            I’m kindly requesting a clean and unlocked BIOS dump for the following HP laptop, as it’s bricked after flashing SP152727. The system now keeps rebooting, and the original issue was an Administrator / Power-On Password that I can no longer access.😏
            🔧 Device Info:
            - Model: HP 15-da2007ne
            - Product Number: 8XF55EA#ABV
            - Serial Number: CND0338P0D
            - CPU: Intel Celeron N4000
            - EC/BIOS Chip: [Add chip number from the motherboard or BIOS chip]
            💀 Problem:😅
            - Device shows “Administrator Password”...
            08-07-2025, 04:54 AM
          • Citymin
            by Citymin
            S/N : 5RNK9FFT70...
            08-05-2025, 05:12 AM
