hp 15-e050sp bios problem
  • highpulse
    i hate HP
    • May 2013
    • 1489
    • portugal
    well another of does monsters that we get from some stored , this time this hp was with a very poorly soldered bios and lifted component near the bios , and they sent us the machine with the tag IN SHORT !!! LOL !!! ok
    well removed bios and put components correctly cleaned all board all good , for my surprise when i open the bios , bios is full of 0 so if someone have a good dump for the following board i apreciate
    DA0R75MB6C0 rev C
    amd cpu
    kbc it8528e
    uma board
    SEND ME THAT BIOS PLEASE
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: hp 15-e050sp bios problem
    backup your old bios and try this
    Im Back... sort of...
    • highpulse
      i hate HP
      • May 2013
      • 1489
      • portugal
      thk ala will try tomorow
      • highpulse
        i hate HP
        • May 2013
        • 1489
        • portugal
        well ok back to this machine sorry for the big delay , well , KBC was damaged since the dc jack light was not working even after bios replacement since the original was empty !!!
        so with new KBC , dc jack leds turn up , machine turns on , but NO IMAGE """!!!
        another things i tryed with some outher dumps even some slicks gave by spider and dycc in outher post , but even does , not working , still turning on but no image ,
        no another thing i noticed , once i insert the battery the dc jack led dont turn on and machine also dont turn , only can notice a very tiny flicker from the dc jack led ,
        bad new KBC ???
        all feedback will be welcome .
        btw replaced the charger ic as well , but same issue .
        apreciate some ideas :P
        thk
        • ibrahim_yas
          Banned
          • Nov 2015
          • 20
          • 86159159666
          Thx for bios file admin
          • highpulse
            i hate HP
            • May 2013
            • 1489
            • portugal
            well , after so many month after this machine , things are different , knowledge is different , so received one with same conditions above , and its a charger issue ! after replacing bq24728 , with a bq24725A motherboard is up and working
            • highpulse
              i hate HP
              • May 2013
              • 1489
              • portugal
              well wrong thread , i was mentioning this for another thread that the machine was not starting , or even getting 3.3 or 5 volts coil
              • rookieme
                • Oct 2014
                • 399
                • Greece
                As I red the whole thread I'll like to ask about the first repair attempt with the replacement of kbc it8528e.
                The question is general.
                A lot of times I have issues with systems that don't power on, some of the have shorted kbc. I replace the kbc with new one and make sure I have working ec and bios but they don't power on. I have the signal from power button coming into the kbc but nothing happens.
                So the question is that these new kbc need programming?
                I have seen some programmers for IT series kbc, are there and configurations for them also?
                • highpulse
                  i hate HP
                  • May 2013
                  • 1489
                  • portugal
                  ITe are not common to keyboard line programming ! usually more into certain ENE modules.
                  actually for my experience , on this board , they got more problems on certain regulator than that on the kbc , usually charger problems , bios , problems , short on some regulator , and yes soemthimes kbc its envolved , well electronics can be a pain in the ass , but following schematic will drive you thru the problem and you'll find pratically always an option and a figure it out way
                  • ibrahim03
                    • Oct 2015
                    • 143
                    • egypt
                    thank you for sharing
                    • karem adil
                      • Oct 2016
                      • 37
                      • alex
                      thanks all
                      • hondaxr
                        • Jun 2014
                        • 21
                        • portugal
                        Thanks worked for me.
                        • yaaqbeh
                          • Dec 2013
                          • 45
                          • palestine
                          • lucaszmn
                            by lucaszmn
                            Problem:
                            Initial Findings:
                            • I concluded that the
                            08-12-2025, 03:01 PM
                          • AquaMan Ua
                            Problem with PANASONIC CF53 laptop after changing BIOS settings
                            by AquaMan Ua
                            Hello. I am asking you for a hint on how to solve the problem with my touchbook Panasonic CF53-2 standart model. After setting up the BIOS, the laptop displays the wrong image until Windows loads. (More precisely, it displays, but distorted, instead of the Panasonic image immediately after turning it on, it displays what is in photo #1 in the attached file) Then the image appears when Windows starts loading and then there are no problems with the screen until the reboot. If you enter the BIOS, just a black screen. If you connect an external screen, the image on it is the same as on the built-in...
                            05-17-2025, 09:40 AM
                          • traxformania
                            TONGFANG "GM7TG7P" Bios Password Problem?
                            by traxformania
                            I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                            But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                            I'm trying to reset my bios without success.
                            I tried :
                            -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                            11-15-2023, 07:32 AM
                          • macabook
                            by macabook
                            🧩 Initial Issue
                            07-24-2025, 02:17 PM
                          • trouble55
                            NEC VersaPro PC-VRT42FBFR22B BIOS problem
                            by trouble55
                            Hi All,
                            [Mother board model]
                            V-VE212(U3E1)
                            [Serial number]
                            24000135PA
                            [BIOS chip model]
                            Macronix MX77L12850F
                            I am having some problems with the BIOS of my Versapro PC-VRT42FBFR22B.
                            I extracted the BIOS file (versapro001.bin 16MB) from PC-VRT42FBFR22B ROM (MX77L12850F) using CH341A and NeoProgrammer V2.2.0.10, but I don't know how to remove the BIOS password, so I can't open the BIOS even if I boot with F2.
                            I also downloaded the BIOS update package (933A0400.zip) for PC-VRT42FBFR22B from the official...
                            09-19-2024, 01:24 AM
