Toshiba C50-a628 BIOS need.
  • rfred17
    • Feb 2021
    • Philippines
    Re: Toshiba C50-a628 BIOS need.
    can someone help me here since I cant post my device TOSHIBA SATELLITE C50-A628 has no display, motherboard number: HannStar J MV-4 94V-0 E89382, I already flash bios bin file given on this thread but still no display
    • vrem
      • Apr 2015
      • 20
      • italy
      Originally posted by nazrul145
      Your second uploaded dump also no power, I have upload my working dump below.
      perfect working
      • ruslan657
        • Mar 2016
        • 70
        • Azerbaijan
        thanks working
        • throwaway327
          by throwaway327
          Model No: RC72LA
          Serial No: SBNVKD001014459
          06-18-2025, 05:52 PM
        • q2v5
          Lenovo T480s, what's up with this Bios, modded boot logo, reflashed now bricked
          by q2v5
          Lenovo T480s
          Model 20L8-S3TE00
          Board ET481-U10
          Chip MX25L12873F
          Hi, I have a few of these & they came with a custom bios boot logo, no passwords etc.
          2 x were brand new unused but with custom boot logo, 1 I installed Windows/ran updates then it bricked itself. 1 wouldn't get past the custom bios boot logo.
          The third I loaded windows, took a backup of the bios chip, then tried to flash several different clean bios's via programmer which all caused it to not boot. I tried to reflash the original bios both using clip & desoldering but...
          08-15-2024, 10:40 PM
        • Neddsme
          Bios partially corrupted somehow and now warm boot doesn't work which is critical
          by Neddsme
          Hie.
          I own a Lenovo ideapad v310-15IKB with an i5 7th generation with only Intel graphics configuration.
          Now the heart of the problem is that I don't know when or how it happened but I suddenly started getting distortion in the graphics output on the LCD. This basically meant a black screen full of flickering multicolored short horizontal lines. This would happen 30-60 minutes after booting and using it normally.
          I run Windows 10 20H build so I thought it was just a Windows update issue or graphics driver outdated issue.
          I managed to run Windows troubleshooting and...
          02-04-2022, 05:57 AM
        • Max029
          Lenovo LOQ mdl 151RH8 bios Q: Can't get usb boot to list
          by Max029
          I've searched and read Beginners guidelines and other sticky threads. This is just a simple bios question. If I may, I'm having trouble finding any help, including from lenovo tech support & forum, for how to get usb boot to list in boot options. I'm trying to run memtest86 so nothing as highfaluting as re-install, flash a bios, etc.
          I've made usb boot enabled and secure boot is disabled. I can find no other option in bios ver LZCN34WW (the original bios). Would anyone here be familiar with LOQ or Legion bios versions & know what is going on?
          TY,
          08-18-2024, 08:28 PM
        • 0xx
          2022 Razer Blade 14 (RZ09-0427) won’t boot after Windows update, only the green LED blinks - overheated or BIOS?
          by 0xx
          Hi folks,
          My son clicked “Update and Shutdown” on a Razer Blade 14 (2022, RZ09-0427), closed the lid, disconnected the charger, and put the laptop in his backpack. The next day, it wouldn’t boot: only the green LED blinked, no fans, no keyboard backlight, no display. The chassis does get warm, so the CPU/GPU seems to get power.
          What I’ve tried so far: disconnecting the main battery, CMOS reset with power drain (30s), using a different power adapter, and connecting to the monitor - same result.
          I assumed that Windows Update was interrupted due to closing...
          09-14-2025, 03:46 PM
