Lenovo Y580 bios dump and ec needed
  • teknikbursa
    • Sep 2014
    • 64
    • turkey
    Hi;
  • alihomee
    • Dec 2012
    • 1598
    • malaysia
    Re: Lenovo Y580 bios dump and ec needed
    any body have i am also looking for this model
    • alihomee
      • Dec 2012
      • 1598
      • malaysia
      anybody
      • aanan
        • Dec 2010
        • 222
        • India
        check this link
        forum.techinferno.com/lenovo.../2260-lenovo-y580-y480-unlocked-bios- versions.html‎
        • alihomee
          • Dec 2012
          • 1598
          • malaysia
          no help.this link is going to same lenovo wibsite which i had check before.the file is not available there.
          • alihomee
            • Dec 2012
            • 1598
            • malaysia
            any body have file
            • alihomee
              • Dec 2012
              • 1598
              • malaysia
              waiting
              • alihomee
                • Dec 2012
                • 1598
                • malaysia
                can anybody upload the file
                • polytek
                  • Dec 2013
                  • 497
                  • TUNISIA
                  here you can download if you are a member:
                  https://www.elvikom.pl/schemat-lenov...7.html#p129720
                  and here:
                  http://www.chinafix.com/thread-849505-1-1.html
                  • alihomee
                    • Dec 2012
                    • 1598
                    • malaysia
                    these formus need login.
                    • alihomee
                      • Dec 2012
                      • 1598
                      • malaysia
                      :any body can help
                      • alihomee
                        • Dec 2012
                        • 1598
                        • malaysia
                        i tried these formus also but they also offering same like lenovo website
                        • alihomee
                          • Dec 2012
                          • 1598
                          • malaysia
                          anyone
                          • khaahk
                            • Dec 2013
                            • 830
                            • Estonia
                            If you are asking for help then give some info to go on!
                            Platform? Compal LA-8002p? Old dumps from your board?
                            What size main bios, what size is ec? Does it have external ec bios?
                            KB9012 on this board has internal memory 128kb. Needs to be programmed with special hardware.
                            Attached dumps from official website
                            • laptopservice
                              • Oct 2013
                              • 35
                              • india
                              main bios not working
                              • tatarinbsb
                                • Feb 2018
                                • KZ
                                Anybody find a proper bios for Compal LA-8002p?
                                • imranromi
                                  • Jan 2015
                                  • 1290
                                  • Pakistan
                                  If you need proper bios post old bios and description problem what?
                                  • wieniu
                                    • Jul 2016
                                    • Poland
                                    Readings from a damaged board. LA-8002P Rev.1,0
                                    • Joluvillas
                                      Lenovo ThinkPad L15 Gen 1 i7 (20U4) Bios and EC dump needed
                                      by Joluvillas
                                      Hi all! I was reading on tutorials how to flash a bios to remove password from a bios, and I ended up reading the EC chip instead of the main bios chip, it only gave me a .bin file of 1,024kb, I learned later that that is the EC chip not the main bios chip (I should have read the tutorials here instead before attempting anything, my bad), I went to flash the original backup, the 1,024kb size file into the same chip and laptop is not powering up anymore. I may have screwed the chip or even the motherboard (Hopefully not), I am trying to see if there is a fix before I discard it. I had a couple...
                                      06-18-2024, 10:35 PM
                                    • AHmad_Salal
                                      Need BIOS Dump/ROM for Lenovo Thinkstation p500
                                      by AHmad_Salal
                                      Hello all,
                                      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
                                      11-28-2023, 05:28 AM
                                    • DynaxSC
                                      by DynaxSC
                                      11-17-2023, 10:56 AM
                                    • TacticalFahrrad
                                      [REQUEST] Fujitsu Lifebook E5513 – Full BIOS Dump Needed (.bin)
                                      by TacticalFahrrad
                                      I extracted the official BIOS update package from Fujitsu (contains FJNB2FD.CAP, ~18.7 MB) and tried tools like UEFIExtract, but it seems to only contain...
                                      06-30-2025, 04:09 AM
                                    • hirens
                                      Lenovo ideapad 3 14IGL05 bios dump needed
                                      by hirens
                                      model: 81wh
                                      sn: pf36ta6h
                                      board no: nm-c961 gs453/gs553
                                      hey guys above is my laptop info
                                      it only blinks the power button kindly help me with a working dump
                                      old dump attached...
                                      07-21-2023, 04:48 AM
