Need ec dump for Asus Zenbook 14X UX5401Z
  • cafjc2k
    • Feb 2015
    • lbjhkjn
    Hello! I have an Asus UX5401ZA laptop with a damaged ITE
    I need the EC dump please.
  • hoaca388
    Badcaps
    • Jan 2022
    • 12395
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • pirati
      by pirati
      10-27-2025, 04:20 PM
    • razor_amd
      by razor_amd
      12-15-2020, 07:07 PM
    • DynaxSC
      by DynaxSC
      06-14-2024, 03:49 PM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
