ASUS TP412FA BIOS
  • sk8inmonkey
    • Jul 2025
    • 6
    ASUS TP412FA BIOS
    Hey all,
    I suspect it has a bad BIOS as computer will not turn on, no power LED only charge LED comes on, and fan will come on at full speed. Looking at the dump, it seems that is is bios Rev 300, uploaded from ASUS
    P/N: TP412FA-DS51T-CA
    S/N: LAN0LP01D36142F
    Board Revision 2.0
    Thank you
  • TIXOU14
    GM
    • Aug 2020
    • 18
    • PARIS
    TRY THIS FROM OLD BD JUST FOR TEST
    • sk8inmonkey
      • Jul 2025
      • 6
      Thank you for the quick reply. Same symptom unfortunately. I let it run with fan running full for about 5 minutes, no change. I wonder if the EC is bad?
      • trunguntilyou
        • Aug 2022
        • 367
        • Vietnam
        My computer's hard-wired ram is dead. I removed the hard-wired ram to use a separate ram and have a full power source. Please help me turn off the ram using the bios. Thank you.
        sn: K9N0LP004719364
        sorry i'm in the wrong place but don't know how to fix it ,,, please change the topic for me
      • Stefan Steff
        • Mar 2024
        • 413
        • Romania
        sn: K9N0LP004719364
        Here is your BIOS content with onboard RAM cleared:
        • trunguntilyou
          • Aug 2022
          • 367
          • Vietnam
          This file turns off when the power goes up, the original bios has a standing current of 0.46 A .I tried to do it myself but it didn't work.
          • trunguntilyou
            • Aug 2022
            • 367
            • Vietnam
            I did it right but what SMDFlea shared the current changed a little bit but it still stood still
            • razor_amd
              by razor_amd
              12-15-2020, 07:07 PM
            • pirati
              by pirati
              10-27-2025, 04:20 PM
            • grimacelord
              by grimacelord
              07-10-2025, 02:52 PM
            • jbonavita
              by jbonavita
              Some issues
              Things I tried
              04-29-2025, 09:38 PM
            • throwaway327
              by throwaway327
              Model No: RC72LA
              Serial No: SBNVKD001014459
              06-18-2025, 05:52 PM
