Thinkpad T495 locked BIOS
  • kicker12
    • Jul 2022
    • 18
    • Italy
    Hey! I have a T495 with BIOS password... I tried the LPC bus shorting BUT I haven't been able to get it to work (tamper error, asking for password, various errors): I guess I have now tried thousand times...
    Hence... Here is its BIOS dump: anyone willing to check/help??? MANY THANKS!
    Model: Thinkpad T495
    Motherboard: NM-C131
    Serial Number: PF-1TG5RR
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1317
    • France
    try
    • kicker12
      • Jul 2022
      • 18
      • Italy
      Originally posted by Maxpower3
      try
      Thanks Maxpower3!
      Unfortunately that has not fixed the issue: password still there... :-(((
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1317
        • France
        Thanks Maxpower3!
        Weird
        Did you use the patched file?
        Did it work?
        what password logo
        • kicker12
          • Jul 2022
          • 18
          • Italy
          Weird
          Did it work?
          what password logo
          Yes, I have tried rhebpatched file... Same behaviour as before... I am starting to guess there are different issues on the motherboard...
          • Maxpower3
            Bad Veteran
            • Feb 2018
            • 1317
            • France
            I don't understand anything! Did you do that??
            [ HOW TO USE THE PATCH ]
            STEP 1: Flash and replace current BIOS with the generated patch file
            STEP 2: Boot the machine
            STEP 3: Press ENTER/F1/etc. to enter BIOS settings
            STEP 4: Enter any character when asked for Supervisor Password
            STEP 5: Press enter when it shows Hardware ID
            STEP 6: Press space bar 2x when asked
            STEP 7: Turn off machine
            STEP 8: Restore original BIOS
            STEP 9: Reset BIOS settings to factory default
            [ NOTES ]
            When booting the patched BIOS you might have to:
            - Hold the anti-tamper switch down the whole time (use tape)
            - Remove the hard disk or replace it with a locked one​
            • kicker12
              • Jul 2022
              • 18
              • Italy
              [ NOTES ]
              Yes, patched BIOS flashed... Bottom tamper switch held down... I start the motherboard, Lenovo logo shows up... Then immediately says "bottom tamper error - press esc to continue", than ask for supervisor password.. Note: I am not pressing any key from the keyboard during power on phase, NO SSD connected.
              • kicker12
                • Jul 2022
                • 18
                • Italy
                Ok... Tried again... This time took my time and trued to do everything slowly... I guess I have made the same things/steps as first time but obviously NOT because this time it worked!!! Thanks a lot Maxpower3, I owe you 495 beers!!! 🍺
                • Reynaldo Usman
                  • Jan 2024
                  • 10
                  • Philippines
                  Pls. rebuild/unlock bios
                  Serial Number: PF-1wmxa6
                  history:
                  unit is a locked bios but now only produces chime sound on power on
                  • Markus1741
                    • Sep 2020
                    • 917
                    • N/A
                    history:
                    Hello try this new files .....
                    • Reynaldo Usman
                      • Jan 2024
                      • 10
                      • Philippines
                      TYSM It worked!!!
                      • lucaszmn
                        by lucaszmn
                        Problem:
                        Initial Findings:
                        • I concluded that the
                        08-12-2025, 03:01 PM
                      • fulaphex
                        Lenovo Thinkpad X13 Gen 3 AMD locked bios
                        by fulaphex
                        hello friends - I have purchased a used Thinkpad X13 Gen 3 AMD variant and only after making the purchase I realised that the BIOS is locked. I have spent a bit of time browsing the forum and from what I understand it's possible the modify the BIOS that is currently on the machine and remove the password from that BIOS. For dumping the BIOS from the laptop I have ordered this ch341a programmer. Below is a photo of the password prompt:
                        I have taken the cover off the laptop and I found that "serial number" is "GM-0358MB" and "type number" is "21CN-S19U00"....
                        07-09-2025, 07:04 PM
                      • lashamafia
                        Lenovo Thinkpad T495 AMD bios password locked
                        by lashamafia
                        Hello, i need help for unlocking this Thinkpad T495 SN; PF-1YX1VY try autopatch but it's stay black screen,...
                        11-30-2023, 04:22 AM
                      • MaxonDomkrat
                        Lenovo Thinkpad X1 carbon 11th Gen BIOS problem
                        by MaxonDomkrat
                        Hi everyone.
                        I have an engineering sample of a Lenovo ThinkPad X1 Carbon 11th Gen (TYPE 21HM-2FVT05, S/N PF-40G7CD) with an Intel Core i7 1360P (ES – Intel 0000). Since this is an engineering sample, the BIOS had a massive number of various settings. One day, I was experimenting with the BIOS settings and, after saving them, the laptop stopped booting and played a melody after pressing the power button, signaling error code 0002 (Internal bus error), just like in this post: https://www.badcaps.net/forum/troubl...shooting-lapto...
                        07-30-2025, 01:27 PM
                        Lenovo ThinkPad T495 Notebook T Specification for Upgrade or Repair
                        This specification for the Lenovo ThinkPad T495 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T495 boardview and T495 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                        09-06-2024, 04:10 PM
