Lenovo B590 20208 Bios Problem
  • bbusterscruggs
    • Sep 2025
    • 12
    • Turkey
    Hello, I wanted to update my laptop's BIOS from h1et40ww to h9et92ww. The website says I need to install h9et75ww first, so I tried installing that version first, but the installation failed and when I press the power button, the laptop momentarily turns on and off (the power light immediately flashes). I tried the crisis files with Fn+R but they didn't work (it works for about 30 seconds with Fn+R but nothing displays on the screen). How can I get a BIOS update file that I can use with Fn+R? Maybe I'm naming the files I put on the USB drive incorrectly. The ones I've tried are bios.bin, bios.cap, bios.wph, bios.fd. Has anyone else had this issue and know a solution? By the way, the crisis folder is inside the h9et75ww update. I don't have the original h1et40ww update.
  • peste
    • Dec 2016
    • 13691
    • ROMANIA
    post S/N, full name and model, motherboard model, TYPE,etc.
    • bbusterscruggs
      • Sep 2025
      • 12
      • Turkey
      This is how it is written on the label
      Lenovo B590
      model name : 20208
      SN: WB09338674
      PN: 59354223
      MO: WB02110927
      • bbusterscruggs
        • Sep 2025
        • 12
        • Turkey
        By the way, I tried the file I had with different USB sticks and it still didn't work
        • bbusterscruggs
          • Sep 2025
          • 12
          • Turkey
          I've done some testing. What I noticed is that when I remove the RAM and turn on the laptop, it doesn't shut down. However, since the RAM isn't installed, there's no display. Could it be that the BIOS isn't recognizing the RAM?
          I would be very happy if you could help me.
          • peste
            • Dec 2016
            • 13691
            • ROMANIA
            If the update failed, the bios is corrupted...
            post the contents of the bios chip even if it is corrupted..
            The bios chip must be unsoldered from the board before writing or reading..
            do not use the clip, you may have errors..if you do not have anything to unsolder it with,
            solder wires between the programmer and the bios chip..
            you need an SPI programmer...here is a video for example..https://www.youtube.com/watch?v=DWWi...nnel=ThisIsHow
            • bbusterscruggs
              • Sep 2025
              • 12
              • Turkey
              Thanks for the reply. I'll try to do that and post it if I can. Also, is there a link where I can get the hotfix version of H1ET40WW.
              • bbusterscruggs
                • Sep 2025
                • 12
                • Turkey
                The device arrived at my place late. But I got the file you wanted.
                • bbusterscruggs
                  • Sep 2025
                  • 12
                  • Turkey
                  By the way, I'm sure the original version is h1et40ww, but the content of the backup I took said 84ww, I think. I couldn't find the h1et40ww version anywhere
                    • 22025
                    If the original is h1et40ww then only h1et** versions should be used.
                    https://xor.co.za/post/2021-10-17-lenovo-b590/
                    Quote:
                    Code:
                    board 20206 BIOS version:
                    H9ET63WW (0.63) 09/05/2012
                    H9ET69WW (1.06) 11/15/2012
                    H9ET74WW (1.11) 06/26/2012
                    H9ET77WW (1.14) 10/23/2013
                    H9ET81WW (1.18) 05/12/2013
                    H9ET84WW (1.21 )
                    10/18/2014 H9ET90WW (1.27) 05/08/2015
                    H9ET92WW (1.29), 08/06/2015
                    board 20208 BIOS version:
                    H1ET63WW (1.06) 04.09.2012
                    H1ET69WW (1.12) 15.11.2012
                    H1ET73WW (1.16) 10.04.2013
                    H1ET75WW (1.18) 27.06.2013
                    H1ET84WW (1.22) 26.11.2013
                    H1ET85WW (1.23) 15.04.2014
                    there are also board revisions 20208 with other versions bios
                    H5ET63WW (1.06) 09/04/2012
                    H5ET69WW (1.12) 11/15/2012
                    H5ET73WW (1.16) 04/10/2013
                    H5ET75WW (1.18)
                    06/27/2013 H5ET84WW (1.22) 11/26/2013
                    H5ET85WW (1.23) 04/15/2014
                    • bbusterscruggs
                      • Sep 2025
                      • 12
                      • Turkey
                      Quote:
                      Code:
                      H9ET84WW (1.21 )
                      H5ET75WW (1.18)
                      Thanks for your answer. But I tried the bin files of versions h1et84 and 85. I loaded it into the chip with ch341a. The good news is that the computer no longer turns off when I press the power button. The bad news is that there is no image on the screen. Another thing I noticed is that the fan starts up and once it stops, it continues to run. I think I need to install an older bios version (63ww, 69ww, 75ww) but I can't find it. Could the bios version I installed be incompatible with the ec version running on h1et40ww.
                      • bbusterscruggs
                        • Sep 2025
                        • 12
                        • Turkey
                        This is the latest bios version I installed. Is there an error in the file that's why I'm stuck on the black screen? Do I need to edit the file or something?
                        • bbusterscruggs
                          • Sep 2025
                          • 12
                          • Turkey
                          I'm sorry if my constant texting seems like spam, but this is the EC file I got from the 4 megabyte chip. I don't know if it will be of any use.
                            • 22025
                            The oldest version i could find is h1et73ww ,flash the bios ,then if it boots up run the bios update, it will update the EC firmware.
                            • bbusterscruggs
                              • Sep 2025
                              • 12
                              • Turkey
                              It didn't work. When I installed the 73ww you gave me, the computer didn't respond at all. The version number is not written in the content either. I think I need both the bios file and the ec file. If anyone has it on the forum, I would be happy if they shared it.
                              • bbusterscruggs
                                • Sep 2025
                                • 12
                                • Turkey
                                The solution was right in front of my eyes here. I solved the problem with a file I downloaded from this topic. It contained the bios and ec file and when I uploaded both, the problem was solved. Thanks for your interest and help.
                                https://www.badcaps.net/forum/troubl...s-needed/page2
                                  SMDFlea commented
                                  Editing a comment
                                  I forgot to post the 4MB file, anyway i`m happy you fixed it.
                              • Thomas Dunlap
                                Corrupted/Interrupted Bios Update Lenovo Legion S7 15ACH6
                                by Thomas Dunlap
                                I have a Lenovo Legion S7 15ACH6 that was interrupted during a BIOS update and is now bricked. Symptoms: fans spin, RGB keyboard lights up, but no display/POST.
                                The BIOS chip is a Gigadevice GD25LR128. I’m using a CH341A with a 1.8 V adapter. In AsProgrammer I selected GD25Q128 (since GD25LR128 isn’t listed) and successfully made a dump (BiosDump2_pf3eg12j.rar).
                                My understanding is that I’ll need a known good BIOS dump for this exact model, ideally matched to my laptop’s serial number (PF3EG12J), and that the Windows license key/serial should also...
                                09-26-2025, 12:45 PM
                              • to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e 2H1703-27220F Rev. A Marked as U2501 on the motherboard.
                                by to5it0
                                Need Clean BIOS/EC Bin File for Lenovo ThinkPad Yoga 11e - Stuck with 0275 Error CMS
                                I am attempting a repair on a Lenovo ThinkPad Yoga 11e that is currently stuck at boot with the error: "0275 error CMS" even after setup new bios battery and will not allow me to enter the BIOS/Setup.
                                This is a critical issue that I believe requires flashing the BIOS chip directly using a programmer (e.g., CH341A/RT809H), as standard software updates or resets are not possible.
                                I have opened the laptop and identified the main BIOS chip...
                                10-24-2025, 01:35 AM
                              • mkdj
                                Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
                                by mkdj
                                Dear all,
                                I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
                                Here the steps I have taken to fix the laptop:
                                - downloaded latest BIOS from Lenovo Website...
                                10-18-2025, 03:43 AM
                              • Zarithya
                                Lenovo ThinkPad X1 Carbon 7th gen not booting after failed BIOS update
                                by Zarithya
                                I have a ThinkPad X1 Carbon 7th gen that stopped booting after a failed BIOS update. There is no life from the machine when the power button is pressed, but when the charger is plugged in, the amber charging indicator turns on and the power button blinks three times. The battery does charge, eventually turning the amber light white. I've dumped the BIOS and tried to fix it (but I don't know what I'm doing or how to use Lenovo's update files in this way) and even attempted to overwrite it with other uploads I've found here to no avail. I've posted the dump in the request forum and...
                                11-02-2025, 06:26 AM
                              • mikeybass
                                by mikeybass
                                04-23-2025, 04:30 PM
