ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
  • danielgerman681
    • Aug 2025
    • 6
    • Mexico
    Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a similar case? If so, where can I find the DMI information for my BIOS? Or if not, is there a way to reinject it into the chip?
    Sorry about English, Im bad with the language.
    IDEAPAD 5 15ILT05
    82FG00VELM
    PF2L7LF2
  • m1ch43lzm
    • Mar 2019
    • 1116
    • Peru
    Your laptop has its BIOS split into 2 chips, 8MB + 16MB, there's also a 8MB chip (maybe W25R64FV or similar), read this one too
    DMi data is encrypted, find LENV with hex editor on 16MB chip, then copy both blocks
    It looks like this
Name:	Captura de pantalla 2025-08-27 145740.png
    https://www.badcaps.net/forum/troubl...23#post3659423
    As peste would say, you have everything you need at post # 14, that's the offsets you need to copy from your backup to the clean BIOS
    You can use this tool to decrypt DMI info
    https://github.com/Shmurkio/LenovoDMIDecryptor/
    Usage: LENV.exe bios.bin -decrypt decrypted.bin
    • danielgerman681
      • Aug 2025
      • 6
      • Mexico
      Originally posted by m1ch43lzm
      Su computadora portátil tiene su BIOS dividido en 2 chips, 8 MB + 16 MB, también hay un chip de 8 MB (tal vez W25R64FV o similar), lea este también
      Los datos DMi están encriptados, busque LENV con el editor hexadecimal en el chip de 16 MB, luego copie ambos bloques
      Se ve así
      Haga clic en la imagen para ver una versión más grande  Nombre:	Captura de pantalla 2025-08-27 145740.png Visitas:	0 Size:	115,3 KB ID:	3713282
      Comopezdiría que tienes todo lo que necesitas en la publicación n.º 14, esas son las compensaciones que necesitas copiar de tu copia de seguridad a la BIOS limpia
      Puedes usar esta herramienta para descifrar la información de DMI
      Uso: LENV.exe bios.bin -decrypt decrypted.bin
      Hola,
      mi laptop tiene 4 chips. Un Winbond 25Q128JV, un winbond 25QR64JV, un winbond 25Q80EWNIG y un ATMEL 45DB081D SU954 pero al buscar LENV, solo aparecen 2 resultados y ambos están ubicados dentro de muchos garabatos.
      Un Winbond 25Q128JV, un Winbond 25QR64JV, un Winbond 25Q80EWNIG y un ATMEL 45DB081D SU954. Pero cuando busco LENV, solo aparecen dos resultados, y ambos están entre muchos garabatos .
      • m1ch43lzm
        • Mar 2019
        • 1116
        • Peru
        Please write in english, you can copy paste to Google translate, it's the forum rules here
        Yes, it's supposed to look like that, that "0xBE" character which is repeated, it's the encryprion byte, it changes for every laptop even of the same model, what you call "scribbles"/"garabatos" copy all from 42E000 to 42FFFF including the "garabatos" and Paste write on the clean BIOS at the same offset (Pegar escribiendo, Ctrl-B), file size shouldn't change
        I decrypted your LENV blocks with the tool linked above, someone flashed a different BIOS, model "Lenovo XiaoXinAir 15ITL 2021", it's a China model, type 82GM, S/N doesn't match yours, your original data including Windows key is lost forever, sorry
        Click image for larger version  Name:	ideapad 5 15itl05 decrypted1.png Views:	0 Size:	118.6 KB ID:	3713357
        Also the serial you posted PF2L7LF2 belongs to a Thinkpad T14 Gen 1, check again
        Click image for larger version  Name:	Captura de pantalla 2025-08-27 182221.png Views:	0 Size:	102.5 KB ID:	3713358
        Only flash the W25Q64 and the W25Q128 with the BIOS from post 14 here: https://www.badcaps.net/forum/troubl...tl05-bios-file
        Or the BIOS from post 8, flash both 8MB and 16MB, W25Q64 and W25Q128 https://www.badcaps.net/forum/troubl...62#post1757162
        Should work, but will display INVALID serial number, model, and MTM, if you want you can copy the data from the 16MB BIOS on post 13, decrypt it, edit serial and MTM, encrypt again, flash it
        • danielgerman681
          • Aug 2025
          • 6
          • Mexico
          Please review the structure and advise the correct sequence. I want to populate my BIOS with accurate data.
          Field Notes
          Manufacturer LENOVO
          Model Name IdeaPad 5 15ITL05
          Version SDK0J40697WIN
          Board Product NM-D211
          Alternate Board Product LNVNB161216
          Board Version Rev:1.0
          Board Serial 1499211800457.
          UUID XXXXXXXX-XXXX-XXXX-XXXX-XXXXXXXXXXXX
          MTM 82FG00VELM
          Family IdeaPad
          UUID obtained by scanning the motherboard barcode labeled as “UUID BARCODE.” All other fields sourced directly from the motherboard.
          BIOS was previously flashed incorrectly by technicians using the wrong model. Unsure about proper order: should Board Serial go before S/N or vice versa?
          If anyone has a correctly configured DMI, please share the exact structure or sequence. This will allow me to populate my BIOS accurately.
          • m1ch43lzm
            • Mar 2019
            • 1116
            • Peru
            Try, I edited your info here, used post 13 from here as a template https://www.badcaps.net/forum/troubl...50#post3659250
            UUID i don't know where it is, you can use Golden Key also to fill S/N, MTM, Model and generate a new UUID
            https://www.badcaps.net/forum/troubl...r-bootable-usb
            Highlighted changes in yellow, edited the 2 blocks
            Click image for larger version  Name:	dmi ideapad 5 15iil05.png Views:	0 Size:	143.4 KB ID:	3713983
